Thread: System psi?
    Jul 2015
    Tampa, FL
    18
    System psi?
    Greetings all,
    Spent the last week replacing this and that on the pool and just received a new psi gauge to replace the old one - cracked and unreadable - on my Hayward Star Clear Plus C900 cartridge filter. After replacing the gauge, I restarted the pump, bled out the air, checked for leaks, and then let it run for about 10 minutes before returning to check the psi...which was read a whopping 2.5psi.
    Prior to replacing the gauge, I swapped the cartridge filter for a brand new one. That said, I am thinking I should be seeing something between 10-25psi, but I thought I would run it by the forum in case my expectations were off base. Water is cycling though the system (water feature and return both have decent flow). Although it's not so much on the topic, I was planning on slamming this weekend, and would like to get everything working right/optimized before I start.
    20 minutes in and still steady at 2.5...any recommendations?
    Wade
    10,000 Gallon Pebble Tec
    Hayward Star-Clear Plus C900 cartridge filter
    Hayward 1.5 HP pump
    Pool is filled from city water
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Re: System psi?
    There is no normal PSI, but that is pretty low. Do you have a 2 speed pump? If yes, check pressure on high. If no, then you have an efficient plumbing set up. As long as flow is good at the returns you are good.
    Jun 2014
    Roseville, CA
    345
    Re: System psi?
    My Hayward with a new filter runs ~ 7 - 8 psi without the solar panels on.
    I had a cracked pre-filter strainer and it let small leaves to get in the pump and clog it. You might want to check that to be sure.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Jul 2015
    Tampa, FL
    18
    Re: System psi?
    Looks to be a single speed (Hayward SP3007X10AZ - Model 1081 1.5 HP Motor). Flow looks good to me, and I do like the sound of "efficient"...definitely don't want to fix something that's not broken. Thanks for the reply pooldv!
    Will take a look just to make sure...thanks for the recommendation Chuckiechan.
    Hayward 1.5 HP pump
    30,432
    Re: System psi?
    Is their air sloshing around in the pump strainer basket?
    Is there a chance you used teflon tape on the psi gauge and partially blocked the opening?
