Results 1 to 8 of 8
Thread: Best pump for 10' x 30" Intex Easy Set Pool?
    Jul 2015
    Northern IL
    4
    Question Best pump for 10' x 30" Intex Easy Set Pool?
    I have the standard and HORRIBLE stock pump (300gph) for my 1,000 gallon, 10' x 30" Intex Easy Set Pool. Looking for a replacement but probably won't buy until next Spring - thought I'd find out from the board if the Intex 1,000gph pump for about $55 on Amazon is the best "upgrade" for this little pool?
    Casey's Avatar
    SW PA
    10,461
    Re: Best pump for 10' x 30" Intex Easy Set Pool?
    Welcome to TFP. Anything would be better than what they sell. Let's bump ya to see what others can recommend.
    Jul 2015
    Northern IL
    4
    Thanks, Casey!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I think the 1000 GPH is the largest intex pump that uses the smaller hose size that your pool probably has, however if you are up to doing the necessary modification you may want to look at the intex sandfilter combos.
    dakhath's Avatar
    Jul 2015
    Central FL
    35
    If you stick with an Intex brand filter (cartridge or sand) you can just use two of these adapters.
    http://www.intexcorp.com/10722.html
    Coleman 5300 gal 16'x48" AGP
    Intex Krystal Clear 2800gph Sand Filter Pump 28647EG (56673EG)
    Intex Krystal Clear Saltwater System ECO 8110
    Taylor K-2006 & K-1766 test kits w/ Speedstir and Samplesizer
    Jul 2015
    Northern IL
    4
    Would I really gain much with this size pool going to a sand filter??
    Jul 2015
    Northern IL
    4
    Bump for opinions on sand filter vs. standard 1,000 gph Intex filter ... thanks
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,555
    It's probably overkill, but if money is no issue, why not? It certainly wouldn't hurt anything.
    That size pool can be pretty easily drained and refilled in an afternoon if the need were to arise. My biggest impetus towards getting a sand filter was to eliminate the need to buy filters.
    If you do get one, size it to handle the largest pool you think you may be getting in the next few years. I started with a 10', followed by a 12', then a 14', and now my current 16'.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
