Thread: Cloudy blue water
    Jul 2015
    Broken Arrow, OK
    3
    Cloudy blue water
    I Slammed my pool. I think I might have done something wrong. After 3 days my clorine is still above 8. The TA is 90 CH is 300 PH is 7.5. My pool is cloudy powder blue. What should I do my Cya is 60.
    I have a 15x35' preformed plaster in ground pool. Hayward sand filter. Approximately 24,000 gal water.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Cloudy blue water
    So, tell us from the beginning, step by step, but I think you need to continue, CYA is high, though
    You need to follow this exactly
    Pool School - SLAM - Shock Level And Maintain
    How you tested your pool?
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Jul 2015
    Broken Arrow, OK
    3
    My test kit is a leslie total poolcare DPD test kit. The highest clorine it shows is 5. I've been above that gor 2 weeks
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    If you want to slam the TFP way you need to have a recommended test kit, no shortcuts, read the previous link
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Jess99 View Post
    Hi Jess, and welcome to TFP!
    You can't perform a SLAM with that kind of test kit, so you didn't actually do that procedure. You need a FAS/DPD kit to do one of those.
    Essential Links:
