Thread: Flocculant www.factorydirectchemicals.com
    Jun 2015
    The Woodlands TX
    26
    Just wanted to alert everyone of a relatively cheap way to buy floc if you are willing to spend 100 at a time.
    Total Solutions Pool Clarifier | Factory Direct Chemicals
    Its 4 gallons of floc. Works well for me. They carry other chems as well, like:
    PH up - Sodium Hydroxide and Potassum Hydroxide
    PH down - Hydrochloric Acid
    Anti foam
    Sodium Bisulfate
    25k IG Gunite and failing quartz over plaster, BBB and considering SWG, Hayward DE 60 filter, Hayward 400k heater, Boost-Rite pump to Polaris, Pentair filter pump, Hayward waterfall pump
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Flocculant www.factorydirectchemicals.com
    We don't endorse using Floc treatments on TFP.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    22,551
    As Lisa said, we don't endorse using floc. Besides they label it as clarifier but promote it as flocculent. Those are differently acting substances.
    And why anyone would need 4 gallons of flocculent is beyond me. If your pool is in that bad a shape you're doing a lot of things wrong.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    If it isn't on this list then it isn't in my pool.
    Jun 2012
    western NY
    1,560
    besides, if that "floc" is what I think it is, we use the same type of chem in our plant water treatment system at work. We pay about $100/55 gal drum
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
