Thread: Pool light burn marks
    cubgirl's Avatar
    Jun 2014
    Madison, AL
    12
    Hi everyone,
    So I'm swimming around in my pool and I notice burn marks coming from the light. It's about size of nickel or quarter near light & goes up, thread like. about 3 inches. It's unnoticable unless you dive under & look. The light still works I think (will test tonight).
    What can cause that? I think I should hire pool certified electrician. Guess I'm just looking for anyone who may have experienced something similar.
    Thanks!
    35,000 gallon 20 x 40 IG vinyl salt water using 2 Saltron Retro SWCG
    Hayward Super Pump 1-HP Single Speed and Hayward C5025 SwimClear Cartridge Pool Filter
    Waterco Electroheat 125 Titanium Heat Pump 125,000 BTU
    Polaris PB4-60 Booster Pump and Polaris 280 F5 Vac-Sweep Cleaner
    Coverstar Automatic Pool Cover and Taylor K-2006 Test Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Pool light burn marks
    Are you sure they are burn marks? Could it be algae? Take the light out and see if there is some funky stuff back there.
    Jun 2015
    Wildomar, California
    423
    Never heard of pool light burn marks, but I have seen rust marks from a light screw that was not stainless or something else inside the niche that was rusting.
    Apr 2013
    Sacramento, CA
    2,769
    You get burn marks from arcing -- I don't think it arcs under water can we get a picture? Much ore likely this is rust or algae.
