Thread: Good pool cleaner for Intex Pools
    Please suggest a good pool cleaner to use for the Intex pools. Currently I have a 22ft pool and am running a Sand filter with a 1hp Intex pump. I know that Intex's pool cleaner tends to be a pressure side cleaner and it has VERY mixed reviews. I tried using a Lil' Shark but mine just sits there. Not sure if the issue is the pump losing it's prime or if that cleaner just won't work for that type of pool...Any ideas?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Good pool cleaner for Intex Pools
    I have the intex auto vac and I do like it, but I have to put the filter to recirculate for it to move. I prefer using my pool blaster max and manually vacuuming.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Jun 2015
    central, LA
    3
    Install a hayward wide mouth skimmer, it makes cleaning ur pool easy. pool3.jpg
    18x48 ultra frame, 2150 sand filter, saltwater
