Thread: hot tub question
    May 2015
    Pahoa, HI
    16
    hot tub question
    Good morning,
    I clean and disinfect 2 hot tubs. We use bromine. When draining/refilling or topping off we use non-chlorinated water. Today, I used a chlorinated water source (<1ppm) and the water turned amber... almost yellow, but more golden.
    Is this what happens when chlorine and bromine mix?
    Is there a reason why bromine is being used as a sanitizer? Is there a downside to changing over to chlorine?
    Mike
    90,000 gallon, in-ground, 3 pumps / sand filters, in-line chlorinator on #2. Learning on the job!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: hot tub question
    When I ran my spa as bromine for a short time, I would oxidize with bleach all the time. This is the same as adding chlorine to a bromine tub. Never had any signs of the water changing shades or a yellow color. Yellow or amber or orange color can be an indicator of metals such as iron in the water when the pH is relatively low, such as low 7s. Is there a chance of metals contamination in the water you added?
    Bromine and chlorine are both acceptable disinfectants/sanitizers in spas. I prefer chlorine as I do not like the smell of bromine and I have a chlorine pool so it simplifies my chemicals that I keep on hand.
    Isolated Spa - 345 Gallons
    Mar 2007
    San Rafael, CA USA
    12,082
    If you add a LOT of chlorine to a spa with bromide, then you can have a yellow/brown color from the bromine, but this should dissipate as the chlorine gets diluted (unless you added way too much). This is more likely to happen if the pH is low as well.
