Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Thread: new 2 pool chemicals PLEASE HELP lol
    Jul 2015
    Knoxville
    72
    ok fellas new here and new pool owner, I have owned this house/pool for 2 months now, seems like I'm spending far to much money on store chemicals to keep the water so-so at most, would love to get to the far less expensive and less complicated BBB method, so I got water tested today at the pool store results are as follows, any advice appreciated and welcomed.... last shock was 24 hours ago
    total chlorine-: 4.6
    free chlorine-: 4.2
    ph-: 6.4
    total alkalinity-: 40
    calcium hardness-: 225
    stabilizer-: 0
    26k (roughly, irregular shape) 10' at deepest diving board and waterslide, IG gunite, 1hp Hayward super pump, 3/4 hp pusher for Polaris280, Hayward s244t sand filter, auto tablet chlorinator, clueless owner.... Knoxville tn, #tf-100 owner#
    Jul 2014
    Hudson, wi
    81
    Re: new 2 pool chemicals PLEASE HELP lol
    First off, Welcome.
    Second, read pool school
    third, order a test kit, TF100 best, K2006 OK
    fourth, stock up on bleach, 8.35% to 12.5%
    Good luck, others will add more details that are much better at it than I.
    21,000 gallon IG with vinyl liner, Pentair sand filter, TF100 test kit, pool is about 15 years old.
    new in 2016 - Hayward SWCG with T15 cell
    Jul 2015
    Knoxville
    72
    thank u onestout, I have read extensively over the past few weeks several thousand threads/replies here lol, test kit on order, bleach supply rapidly growing haha, so ready to be done with the pool store......
    Jul 2014
    Hudson, wi
    81
    Not sure I trust your PS numbers. If you have been using the pucks for your chlorine I would think that you should have some stabilizer unless you have ammonia eating everything. If it was ammonia you would have an FC of 0 so I don't think that is it. Until you get your test kit I would use pool math and add the daily bleach needed. I have a smaller pool and I use about 1 gallon of 12.5% per day.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    and you might want to pull pucks from chlorinator in case your CYA is really much higher than 0
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jul 2015
    Knoxville
    72
    Yeah I thought 0 was strange, smh gonna go get some baking soda to raise the alkalinity,
    Jul 2015
    Knoxville
    72
    OK so I picked up lots of baking soda, bleach and borax my next question is do I dilute the borax/baking soda before adding it into the pool? Thanks in advance
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,497
    I would work on the PH first. IT is the most important right now for your equipment.
    PH and FC are what you need to work on right now.
    The rest we will ge tto when you kit gets there.
    I just wanted to jump right in so now I can take a breath and say HI! We are so glad you found us! We can save you SO much money it is not even funny!
    Go to Walmart and get one of those cheap testers. You need it for the PH test. That is the one thing it does right!
    We HAVE to get that PH up if it really 6.4.
    For right now you can turn your returns up so they roll your water and if you have a waterfall or such get it going as well.
    Do NOT allow anyone in the water with the PH that low.
    HUGS! We got ya now!
    Kim
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    There was likely no need to pick up "lots" of baking soda or borax. Just enough baking soda to get your TA to 70-80 or so. Borax you may never need much more than a little. The bleach... you can always use bleach.
    No need to dilute either. Just measure your desired amount and sprinkle in front of a return slowly or around the perimeter of the pool and be sure to brush after adding anything powdered to your pool. It's a good idea to brush in the area where you add bleach (in front of a return) each time as well. Get that pH up first with some borax. TA will come up a little with borax as well so measure that again before adding any soda.
    Isolated Spa - 345 Gallons
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Quote Originally Posted by kimkats View Post
    Kim
    Welcome to TFP
    Kim's right!
    But as much as the cost savings can be great, and it has been for me, getting to really understand whats happening with you pool with little or no aggravation is priceless!
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Jul 2015
    Knoxville
    72
    Ty everybody for the advice, just added 2- 76oz boxes of borax and 1- 13.5 lb bag of baking soda (about half of what the calculator recommended of each) figured I'd retest shortly to see where I'm at
    Jul 2012
    Tallahassee, FL
    30,497
    Good move! let us know what it does!
    Kim
    Jul 2015
    Knoxville
    72
    OK so I added the soda and borax and figured I'd brush the bottom to move anything around if it made it down there, now I vacuumed it 3 days ago and brushed the sides and bottom yesterday, now today even brushing it looks like in pushing some brown dust around down there, now we have gotten some serious rain down here to the tune of me having to drain quite a bit to waste cause the water was really high, should I worry about this now or wait till water is balanced
    Jul 2012
    Tallahassee, FL
    30,497
    You are already killing the bad stuff-GOOD JOB!
    You need to brush at least once a day to keep it good and stirred up and keep it from attaching to the walls.
    Kim
    Feb 2014
    Central Minnesota
    5,080
    Sounds like you've got a great start. I would get some bleach going in the pool. Use your OTO test to get an idea of where your total chlorine is at. Try to get it up to 5 and add bleach if it's below that until your test kit arrives with the CYA (stabilizer) and FAS-DPD FC/CC test that will allow you determine where your pool is at.
    Is your water cloudy, clear, green, swampy? Sharing pictures is very much encouraged. It's best to upload pictures to a file/photo sharing site and post links to them rather than trying to add them to your posts as attachments. New members aren't allotted much storage space on this site and even most senior members choose to link to images posted on services such as photobucket.
    Jul 2015
    Knoxville
    72
    chems are falling into place slowly, now I changed the sand in the filter the other day before I started all the chem adjusting just because I didn't know when the last time it had been replaced, I have added bleach, borax and baking soda between yesterday and today and my pool looks 100x better than it has in a long time the water is blue but is cloudy
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    looking good...do you have new test readings?
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Jul 2015
    Knoxville
    72
    not yet I think my dum-dum strips are lying to me so I'm about to head out and find something to use until my tf100 arrives (hopefully not long) lol
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Quote Originally Posted by ignoranceisbliss View Post
    don't waste your money. you wont find anything local unfortunetly. the TF-100 comes from North Carolina so you should have it soon. usually about 2 days
    Dan
  20. Back To Top    #20
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    LOL @ dum-dum strips.
    The kit Kim mentioned earlier can help you work on your pH till your TF-100 arrives. It will be the one that has the drop test with the little color block that is shades of yellow to pink on one side for pH and shades of yellow on the other side for FC.
    You're gonna get one with your TF-100 but if it's cheap enough I guess it's not too bad to get one ahead of time to make sure your pH level isn't damaging anything.
    Do you have a tracking number for your TF-100 yet?
    *edit*
    Dan has it right though, if your kit is going to be there really soon I wouldn't spend much on something you're only going to use for a couple days.
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
