Thread: CH reagent R-0011L droplet size?
    Jun 2015
    Glendale, AZ
    156
    Anyone notice that the reagent R-0011L drop size smaller than all the others?
    I don't know if it is my eyes or whatever, but doing the CH test, the reagent R0011L blue drop sure appears smaller than any other tests. Maybe the chemical makeup of the liquid gives that appearance, maybe it is just me.
    I have changed different tips, changed using 3 different bottles, wiped between drops, still the droplet each and every time appears smaller than all other tests. My tests are consistent, it is just the drop size I question.
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: CH reagent R-0011L droplet size?
    I think it's the viscosity of the liquid, and that it somehow creates that illusion. I'm not wild about this indicator, and use a good deal more than the instructions call for. Unless a dropper tip is calibrated, the drop sizes won't really vary much as far as I know.
    Essential Links:
    Jun 2015
    Glendale, AZ
    156
    Quote Originally Posted by Patrick_B View Post
    Your insight makes sense to me, it appears as the drop forms its weight releases earlier than the clear liquid reagents and maybe the droplet size is smaller.
    I believe all the tips are the same for all reagents, as I have ordered replacements and Taylor only shows the one number.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I believe that is correct. That said, I work in an industry where we use basically the same, but other drop tests for a number of things and many of those have calibrated tips, or droppers. Often, the tips are concave, but not always.
    Essential Links:
    Jun 2015
    Glendale, AZ
    156
    Thanks for your info...at this point I will not worry, likely droplet size on this test has been factored in by Taylor and correct.
