Results 1 to 8 of 8
Thread: Led Pool Bulbs
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Led Pool Bulbs
    Any recommendations on a led bulb for pool & spa 12 volt white...Thanks
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    Jun 2015
    The Woodlands TX
    26
    Re: Led Pool Bulbs
    You should specify in-ground or above ground. The lights are quite different. I noticed ebay has a lot of above ground lights for great prices that are held to the side with magnets. I've never used an LED light for the pool, so no recommendation but I'll watch for what you find to work.
    25k IG Gunite and failing quartz over plaster, BBB and considering SWG, Hayward DE 60 filter, Hayward 400k heater, Boost-Rite pump to Polaris, Pentair filter pump, Hayward waterfall pump
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: Led Pool Bulbs
    Sorry it's inground, for pool & spa I am looking for...I found many for pool but not many for spa.
    Autopilot SWG
    Sep 2014
    Fort Lauderdale, FL
    146
    Re: Led Pool Bulbs
    I recently bought one from 1000bulbs.com, and I'm very happy with it. 6500kelvin color (bluish white), and just 18 watts.
    15k in-ground plaster, Hayward C900 cartridge, 1.5hp Pentair SuperFlo VS pump, Hayward AQR15 SWG, Barracuda G2 suction cleaner, TF-100
    Sep 2014
    Oviedo, FL
    4
    Re: Led Pool Bulbs
    Quote Originally Posted by jeffbrig View Post
    How do you like the brightness of this light? The 6500K temperature should be great for a pool, but the Halco 80134 light only has 1400 lumens.
    I was also looking at the Kobi LED-2780-R40-50 - Dimmable LED - 27 Watt - R40 light which is listed at 2780 lumens. Unfortunately it is a 5000K temperature so it is not as blue as the Halco.
    2001 15,000 gal IG plaster pool with spa, screen enclosure, Jandy 1.5HP 2-speed FloPro pump, Hayward C1200 star-clear plus cartridge filter, Hayward H300 pool heater
    7 FAFCO solar panels w/Goldline GL-35 controller, TF-100 test kit w/ SpeedStir
    Sep 2014
    Fort Lauderdale, FL
    146
    Re: Led Pool Bulbs
    I imagine it's pretty subjective how bright you want it to be, but I'm perfectly happy with the output. My pool isn't huge, about 14x28, and it seems about right to my eye. I've posted a pic in another thread, let me see if I can dig that up...
    Sep 2014
    Fort Lauderdale, FL
    146
    Re: Led Pool Bulbs
    Sep 2014
    Oviedo, FL
    4
    Re: Led Pool Bulbs
    Love the 6500K temperature. That picture sure seems like the Halco is putting out more than 1400 lumens, but I guess that is pretty subjective.
