Thread: Testing/Balancing Pool+Spa Combo
    dtrujillo63's Avatar
    Feb 2015
    Los Angeles
    33
    For those of you who have pool and spa combos, do you test and balance each body of water separately? I've only been testing and balancing my pool water but I do have the pool water circulating through the spa. I'm wondering if that's sufficient.
    30 x 20 IG Play Pool + 7' Spa ~16K Gallons, French Gray Plaster, Pentair Intelliflow VS, Pentair CCP420, Pentair MasterTemp 400K Heater, Intellibrite LEDs.
    robbief00's Avatar
    Dec 2014
    TX
    40
    Re: Testing/Balancing Pool+Spa Combo
    Do you have a return in the spa so that the spa water overflows into the pool whenever your pump is running? If so, I would think it would be balanced fairly closely to your pool water (unless you just added chemicals to the pool and it hasn't had a chance to distribute yet through the plumbing.
    Mine is set up this way and I have never tested the spa water. I have only pulled my test water from the pool.
    My Pool Build
    15k gal IG freeform w/ attached spa, Wet Edge Luna Quartz Bermuda, 3.5' to 5.5' depth, Intelliflo VS pump, Cartridge filter, MasterTemp heater
    1 hp Whisperflo for ledge bubblers/weeping rock wall, Polaris 280, EasyTouch 8 Automation, Intellibrite 5G color LED's, TF-100 w/ Speedstir, Stenner Peristaltic Pump
    Feb 2015
    Los Angeles
    33
    Yup, my spa spills over into the pool. I was curious to know how everyone else does it.
    Thanks!
    JoyfulNoise's Avatar
    May 2015
    13,265
    I test pH and drop it to 7.4 prior to use. I do not use my SWG during spa use (even on the lowest output setting, it raises the FC too much for my liking). Afterwards, I test pH/FC/CC and then turn on the SWG for 30-60mins (low speed, no heater) to bump the FC back up and oxidize the bather waste a little. Then I dump it all back into the pool and let it run normally (spa spillway) for another hour.
    I might use the SWG if I have a spa party but it's typically just me and the wife.
    Matt
