Results 1 to 7 of 7
Thread: Have to show off TFP results
    PoolESQ's Avatar
    Dec 2007
    Albuquerque, NM
    191
    I've been following the TFP method for many years - from back when it was called the BBB method. After moving to a new home with a different type of pool, a renovation, well water issues, and automation issues things are finally back to perfect thanks to everyone's help here. I wanted to post a couple of pictures to show just how awesome your pool can look by following the advice of this great forum. Thank you to everyone who has assisted me in this effort!
    Replastered 2015: Sunstone Quartz Midnight Blue 16x32 rectangular gunite with in-pool spa....18,000 gallons. Autopilot Total Control System with SWG and acid pump. Pentair Clean & Clear 420. Auto cover. TF-100.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Have to show off TFP results
    Fantastic pool!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Awesome pool with sparkly water!
    I bet with the vineyard in the back you get plenty of dirt/dust in the pool. Looks like in-floor cleaning system? Does it work well? I'm sure the autocover does help keep most of it out though.
    Isolated Spa - 345 Gallons
    PoolESQ's Avatar
    Dec 2007
    Albuquerque, NM
    191
    Thanks guys!
    JVTrain - yes, that's an in-floor cleaning system. We do get a good amount of dirt/dust in this area and the cleaning system works extremely well on that and stuff like pollen and bugs. For larger debris such as big leaves, bark (my tree sheds it's bark one a year for some strange reason) it's not so good. On the plus side, the system does push all of the larger debris to one corner of the pool so it's very easy to scoop/vacuum out. And yes, the autocover helps a ton!
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    what a beautiful pool and view!
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Casey's Avatar
    SW PA
    10,448
    So very nice!
    PoolESQ's Avatar
    Dec 2007
    Albuquerque, NM
    191
    Thanks!!
