Thread: Concrete pool deck repair advice needed
    Sep 2008
    Philadelphia
    43
    Will be replacing the cut section in below:
    Note the use of the white, plastic, expansion strips already present.
    I can't find out who the original contractor is to do this or to find out what he used (he was a sub and pool company out of business). I think I found a product that is similar if not the same:
    It is from:
    http://www.stegmeier.com/index.php?o...=92&Itemid=120
    They call it:"Frontier Deck Joint . Frontier Deck Joint is an extruded PVC deck joint material available in 12 foot lengths. This product is placed into freshly poured concrete to create an effective weakened plane. Frontier Deck Joint's design features "T" members that provide a water stop. If a full expansion is necessary, or a detailed pattern is desired, use Frontier Deck Joints in combination with Frontier Rigid Hold."
    The item is .6" wide x 1.3" high. If I use the Frontier Rigid Hold:
    , it is same width and 3" high.
    Aside from how it might look (perhaps odd), which, if either system, should I use?
    Since it is around a pool, I am thinking this plastic stuff will protect toes/feet from a raw concrete edge. I could use a rounding-over masonary edging tool but that also might look a bit odd since it would be the only place in the pool area where that treatment would be used.
    I know this is a 1st world problem, but I've come this far and don't want to screw it up!
    TIA for any advice.
    25,000 gallon
    16' x32' Rectangle IG, Vinyl liner
    DE filter
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Re: Concrete pool deck repair advice needed
    Are you sure you want/need expansion strips around this?
    It was already part of a single deck segment.
    Couldn't you drill into the edges of existing deck and epoxy rebar into those holes then concrete that section to make it homogeneous?
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Sep 2008
    Philadelphia
    43
    I could go several ways on this and wanted to hear the opinions of others without coloring their recommendations.
    Your thoughts are perhaps my option 1.
    Open to the ideas of others!
    Thanks!
    25,000 gallon
    DE filter
    Sep 2008
    Philadelphia
    43
    Thanks Oz.
    I repaired the area yesterday; used no expansion joint materials.
    Now curing; will see what happens as time progresses...
    25,000 gallon
    DE filter
