Thread: Slam + mustard algae clarification
    Jul 2015
    Charlottesville, VA
    8
    I am in day four of SLAM for cloudy water and MA. I just noticed more MA growing than I have seen on days 1-3. There is also more gray powdery residue so I do think I am making some progress.
    At a 50 CYA, I have aimed for 20 ppm FC with the understanding that once the pool passes three SLAM criteria, I then increase to 29 for 24 hours and then let drift to maintenance levels. Am I correct? Any advantage to jump up to 29 sooner?
    thanks!
    2015 installation, 18,000 gal. fiberglass, Coverstar Auto cover, 300 lb SandMaster filter, 1.5 HP Pentair SuperFlo pump, AquaRite SWG
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Slam + mustard algae clarification
    It doesn't hurt to shoot for slightly above 20 at this stage but up to 29 now won't make much difference. Going slightly above target means that your more likely to still be near the 20 ppm mark more often.
    Isolated Spa - 345 Gallons
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    No real advantage. Just do your best to keep FC above the minimum regular shock levels until you pass the three criteria then go to MA levels for 24 hours. Brushing your pool will provide the most benefit at defeating the algae, more so than raising the FC level.
    Good luck.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
