Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Paver Installation
    Paver Installation
    Hello
    we had a large steel wall pool installed last summer and are planning to have a patio installed. We are going with pavers but hear conflicting ways of installing them. We live on Long Island NY so I waited to go through the winter for the ground to settle, which it surely did. I am going towards putting the pavers over poured concrete at least 4' out from the pool and the larger area may be put on crushed stone. I'm told the concrete slab will bridge between the coping shelf and the undisturbed soil. Problem is that all the paver manufacturers recommend putting them on crushed stone. I would appreciate any thoughts so I can avoid an argument with the boss (my wife) She says crushed stone.
    In addition we have a salt water pool if that matters
    Thank you
    Tom
    Oct 2007
    Valrico, FL
    542
    Re: Paver Installation
    I have pavers around my pool. Most of the pavers were placed over crushed concrete. However we also have an existing patio which has a concrete slab. Pavers were placed over this concrete slab also. The end result, you really can not tell where there is concrete slab and were there is crushed concrete. I believe that the crushed concrete would be less expensive. You will also need under deck drains. Both the concrete and the crushed concrete is relatively impermeable to water, so you need drains to prevent flooding during rains.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    I hope your pool wasn't backfilled with dirt. It almost inevitably settles. Usually sand or crushed rock is used.
    Whatever kind of deck you put in, don't neglect a bonding grid. We have a member here who has problems with electrical shocks from an unbonded paver deck, and numerous folks who experience the same thing with unbonded concrete decks. If you pour concrete and bond it, you can probably put pavers over the top and be fine. Bonding is an electrical connection of the walls of the pool and anything metal that is within 5ft of the pool. Very, very difficult to correct after the deck is installed. Easy to do before you install it.
    Thanks for the replies. I'm still confused as to which way to go however. I'll keep the deck bonding in mind.
    Thanks
    Tom
    30,411
    There would be little doubt in my mind to go with crushed stone underneath the pavers. Simply, it is a more forgiving installation.
    If your dirt continues to settle (it will) the pavers will ride with it and if it settles too much you can simply lift off the pavers and put in more crushed stone.
    Cheaper and more suited to your installation.
    About the only disadvantage is that grass and weeds will attempt to get thru the crushed stone but it's so very little, it is quite controllable.
    chezhed's Avatar
    Mar 2009
    Mission, TX
    37
    You can avoid the grasses and weeds growing by placing black polyethelene film down before spreading the gravel. Or you can use Gator Dust (a polymeric sand) between the pavers instead of sand.
    11,000 gal + overflow spa, IG gunnite, Pentair 48FNS DE filter, Hayward SP3210X15 pump, CompuPool CPSC36 Chlorine generator, pool valet w/5 zones, Pentair LP heater
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    I second the polymeric sand. Its self healing and wont wash away. Ants do not like it as much either.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Apr 2009
    25
    Hi , I'm a concrete contractor from minnesota, all we do are pool decks, all our pavers are on concrete. The reason is simple , once you pour the concrete base all slop to grade is done no need for drains , we use rebar in our concrete which make it self supporting so even if the soil settles your deck will carry any weight you put on it , no bugs , no drainage problems, no movement, no weeds. they make a 25 mil paver so your cost is less. call me I can better explain on the phone 763-421-1736 Brad
    Quote Originally Posted by sandybeach
    Good to know.. I am in MN and may need some concrete work around my pool.
    2003 Marquis Euphoria - 400gal
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    "Crush & run" is a popular base for pavers in my region. If you are using "driveway" type pavers, you are good to go with all above. If you are using a Travertine or the expensive-but-excellent Artistic pavers, you might want to not use a concrete base. These types of "pavers" are not the same.
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    Mar 2007
    Coastalish 'down easter'
    4,160
    I'd like to say HI to Brad and welcome him to TFP!!
    Brad, do you do all kinds of pool decks or just pavers? It'd be great to have an expert on decks here 8) (there have been quite a few questions on 'cool decks', cleaning concrete decks, etc that I can't answer, though I have to walk on them to get to the pool . Do you have your own pool, if so show us some pics or tell us a little about it .
    Budster, a small note on terminology, "crush and run" sounds ~phonetically correct but it's actually "crusher run" (at the gravel pit they have big rock crushers that 'grind' the stone to the various grades -like #57 or 3/4" gravel - the "run" is the finer stuff that they collect after making, screening and rinsing the freshly crushed stones ) (I'm telling you this out of friendship, not trying to pick on you - when I worked up in NH, I referred to the board used to level the concrete in a poured pad as a "screet" board and caught a LOT of flack [ ] from my co-workers because the proper name is a "screed" board - I just didn't want you to ever run into ignorant folks like that who will pile '****' on you for using a close sounding, but incorrect, term )
    Luv& Luk
    -Ted
    I had just asked the contractor about putting the polymeric sand between the joints. His answer was he did not recommend it because it doesn't let the water drain though. Is he trying to just blow it off or is he correct?? He also stated weeds will only grow IF dirt is dropped onto patio as it would not grow up from the bottom
    Tom
    chezhed's Avatar
    Mar 2009
    Mission, TX
    37
    He's full of bull
    I have a section I did last year to see how this stuff works. Water does not pool on it. Plants do not grow through it. I also have two other experimental sections, one with sand and one with pea gravel. Water doesn't pool on them.....but plants grown in each of them. I will be finishing the entire area (flagstone) with Gator Dust this summer.
    Weeds grow because seeds are dropped/blown etc. from the top. They only need a rooting base.
    Sheesh, we used sand for a plant medium in third grade....guess your contractor only got to second.
    OK thanks I'll tell him to go with it the polymeric that is
    Tom
    Installation didn't go so well
    It seems these guys have never used polymer sand or read the directions on the bag. Here in NY today it was drizzling on and off so the pavers for the most part were wet before or just after the sand was put down. They also used a stream of water from the hose to remove the "soapy water" from the pavers. I read it should been only a mist of water. They were also walking on them afterward. Guess they are accustomed to working with regular sand. What do I look for now, I already see some joints do not have enough sand in them. Anything else??
    Not happy
    Tom
    Apr 2009
    25
    Quote Originally Posted by tpm
    Not happy
    Thats not soapy water , thats the glue {polymer]! Every part of the job has to be dry, the sand base , paver , broom you use to sweep the sand into the joints. even if the sand base looks dry ,give as much time as you can , because the pavers will weep water from the soil. thats another reason we use concrete , once its cured completly than you can install your paver with out worry of water weeping from below. you can waite until everything drys out and sweep more sand into your joints, when your done dont wash the pavers off just mist them and watch the white glue flow into your joints. after some good weather and all the miosture is gone you should use a good sealer on your pavers, we use super diamond clear for a wet shine look. dont put it on when its wet or it will dry white. dont panic if it does another coat of sealer will bring it back to shine good luck Brad
    Apr 2009
    25
    Quote Originally Posted by waste
    Thanks for the welcome, we do anything with concrete, paver exposed agg, color stamp,Ill try and get pics of our pool on here this weekend . any help I can be just ask Brad
    30,411
    Well, Ted, Here in the South (The cultural center of the US) it is "Crush and run". As Budster will tell you, we "Crush" a little rock, and then "run" to the store for some more beer......it's almost impossible to make a uniform mix without the beer.....but don't get the notion we mix it with the rock, tho.
    Shoot, Ted, ya'll up there probably think when we "carry" someone to work, we're not givin' 'em a ride in the car!!
    Mar 2007
    4,160
    Heck, Dave ol' boy, twas in Va, that I heard the term 'screet' board - It was those fast talkin' New Hampsterites that gave me gruff about it being a 'screed' board
    Were it up to me, I'd be down there in the 'cultural center of the US', however , the wife wants to stay close to her family in NY, Mass, and Maine
    I HOPE I made it clear that I wasn't trying to pick on nor poke fun at Budster, only trying to keep him from catching the same '****' I caught for a similar 'indiscretion'
    Dave, do you play golf? I'm overdue to see my father in ~ Wilmington, I'd love to hook up with you, drink a few beers, talk pools and loose some golf balls to whatever water hazard (I know water isn't magnetic, but try explaining that to any golfball I hit )
    Luv& Luk
    -Ted
  20. Back To Top    #20
    chezhed's Avatar
    Mar 2009
    Mission, TX
    37
    Not happy
    Hmmm, no wonder they were steering you away
    It will clean up as sandybeach said. I had some damp stones when I first put some dust in and freaked out when everything went white. But it cleared up with a mist and a broom. But next time, I will make dang sure things are COMPLETELY DRY.
