Thread: Woo Hoo-am I really done with this slam?!?
    Jun 2015
    O'Fallon, MO
    45
    OK, peeps, overnight chlorine loss was 1.0. Should I slam the rest of today? The pool is clear, CC is 0, but there is some sediment at the bottom. I'm going to scrub, filter a while, & backwash again in about an hour-have to run daughter to camp first. What say you-am I done?????? If so, then do I just test daily to maintain chlorine? What level? Thanks!!!!! So hopeful...
    24 x 52 intex AG round with well water-water has no issues with rust or other contaminants
    2800 GPH Intex sand filter pump
    Located in Missouri
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: Woo Hoo-am I really done with this slam?!?
    what level was your FC when you measured a drop of 1ppm? personally I ran my SLAM until I had 0.5ppm loss and confirmed for two consecutive nights. if you have sediment on the bottom you need to get that out. that's part of the pool being clear criteria, no remains of algae (dead or alive). keep brushing/vacuuming and get it out.
    how clear is the pool? can you read a quarter heads/tails in the deep end?
    what level is your CYA? see the link in my signature. once you are done with the SLAM, you let your FC drift down to the "target" level and never let it get below the minimum level based your CYA level.
    once your FC drops below 10ppm, you need to check your pH and adjust. I would run a full set of new numbers and post them. time for any tweaks that may be needed. the main things you will be adjusting go forward is just FC and pH
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    aboykin2269's Avatar
    Jun 2015
    Charlotte NC
    225
    +1 for what Dan said. I ran my SLAM until my FC loss in the OCLT was .5ppm for 2 nights in a row. You really need to know your CYA in order to properly target your FC level.
    Ant
    16'x48" Summer Escapes Pro-Series, AG, Ultra-Frame, Intex CS15110 Sand filter/SWG, 5061 GAL, TF-100 Test Kit w/ K-1766 Salt Test and Speedstir.
    Pool School, ABC's of Water Chemistry, CYA/Chlorine Chart, Water Balance for SWG's, Pool Math.
    Jun 2015
    O'Fallon, MO
    45
    Thanks, I figured as such, but wanted to make sure. My FC was 12 last night & 11 this morning. Yes, pool is crystal clear to see a quarter. But, I'm going to keep slamming & remove the debris. I did remove pool ladder & saw algae on it. I still need to scrub in down before anymore swimming. Thanks for the advice. I haven't run the CYA b/c it only completely dissolved a week ago today. An earlier poster said to run it this weekend. I figured I might do a complete test tomorrow as I'm having my family over Saturday to swim so that would give me some time to adjust things. Does that sound like a plan?
    Located in Missouri
    Jun 2015
    Charlotte NC
    225
    Quote Originally Posted by needmypoolboy View Post
    Yes. Do your OCLT one more time, then you can be sure. Once you get your CYA reading, use this chart http://www.troublefreepool.com/conte...art-slam-shock
    to find your target and minimum FC level. Then go an enjoy your pool!
    Ant
