Results 1 to 17 of 17
Thread: Jandy LT400
    Jul 2015
    Fairport
    9
    Jandy LT400
    Good morning
    So down to it, the problem that is!
    I just purchased a used Jandy LT400 from a friend. I have it plumbed and wired...
    When I first turned it on, it went through diagnostic, then threw a pressure switch light... so I replaced it.
    Tried again...still have the pressure light flashing... so I turned down the thermostat on the pool side...and the light stayed off. As I turned the knob towards the red, there was a small click, and the light came on and started flashing. I repeated this process multiple times...
    Could use some help here... Thanks so much in advance!
    James
    Pool Noob
    16000 Gal Inground
    Jacuzzi Magnum Pump
    Sand Filter
    Jandy LT400 Heater
    Jun 2012
    western NY
    1,562
    Re: Jandy LT400
    The pressure switch light does not indicate that it is bad. It indicates that the pump pressure is not sufficient to close the contacts and allow the heater to fire. You may need to use a higher speed on the pump if possible to get the switch to close.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jun 2015
    Wildomar, California
    423
    Re: Jandy LT400
    Also make sure your filter is clean, and the baskets too!
    Jul 2015
    Fairport
    9
    Re: Jandy LT400
    Filter basket is spotless...well, not spotless...its old...old things have spots...Im old, I have spots...
    I just replaced the motor, its a 53J (I think) 1HP motor...
    Flow through the copper tubing is strong, its got to be more that 2psi... No?
    Quote Originally Posted by danpik View Post
    Pool Noob
    16000 Gal Inground
    Jacuzzi Magnum Pump
    Sand Filter
    Jandy LT400 Heater
    Jun 2012
    western NY
    1,562
    Re: Jandy LT400
    With the power off and one wire unhooked from the pressure switch, Turn the pump on and measure the resistance across the two contacts on the switch to see if it is closing. Paul may see this and comment on it as well. May be something in the inlet of the heater not allowing enough flow.
    Jul 2015
    Fairport
    9
    Re: Jandy LT400
    Thanks for that, will do that and post the numbers. It will have to wait until a bit later, new liner is being installed as we speak/type/whatever...
    Pool Noob
    16000 Gal Inground
    Jacuzzi Magnum Pump
    Sand Filter
    Jandy LT400 Heater
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    Re: Jandy LT400
    Is the service light coming on? Is there any type of automation on this system? If so, This is a normal display when a device connected to the “Fireman Switch” operates to open the safety circuit on the heater.
    Paul
    http://www.gastekservice.com If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - http://www.youtube.com/c/Gastekservices
    Jul 2015
    Fairport
    9
    Re: Jandy LT400
    No service light. I won't be able to work on this until the installers come out this morning and pull the blowers and cut in the skimmer drain and nozzles... I'm pacing around my deck...lol
    Pool Noob
    16000 Gal Inground
    Jacuzzi Magnum Pump
    Sand Filter
    Jandy LT400 Heater
    Jul 2015
    Fairport
    9
    Re: Jandy LT400
    .02 Ohms with one wire detached. Its very odd, the pressure switch light doesnt come on, until I turn up the temperature knob. It does it at the same place every time.
    Pool Noob
    16000 Gal Inground
    Jacuzzi Magnum Pump
    Sand Filter
    Jandy LT400 Heater
    Jul 2015
    Fairport
    9
    Re: Jandy LT400
    Anyone have any ideas on this? I can hire a tech I suppose, but if no one has an idea here...he/she most likely won't either... Lol
    Pool Noob
    16000 Gal Inground
    Jacuzzi Magnum Pump
    Sand Filter
    Jandy LT400 Heater
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    Re: Jandy LT400
    You say you purchased it used. Do you know if the previous owner had it hooked into any type of automation system?
    Paul
    Jun 2012
    western NY
    1,562
    Re: Jandy LT400
    Quote Originally Posted by Hollywood151 View Post
    That is almost no resistance so I would say the pressure switch is closing. Does the resistance change when you cut the pump off? It should go up high or show the infinity symbol on the screen (or what ever the meter shows for open circuit)
    Jul 2015
    Fairport
    9
    Re: Jandy LT400
    I do not know, but my assumption is no. It was a pretty clean disconnect. Safety loop is in place and there are no extra wires nor any connections missing.
    Quote Originally Posted by ps0303 View Post
    It does change when the pump is turned off.
    Anyone need an LT400 for parts? I'm frustrated, I cant seem to find another occurance where turning up the temperature knob makes the pressure switch light come on.
    Pool Noob
    16000 Gal Inground
    Jacuzzi Magnum Pump
    Sand Filter
    Jandy LT400 Heater
    Jul 2015
    Fairport
    9
    Re: Jandy LT400
    Have I officially stumped the entire forum? I always knew I wanted to be famous...just not for something like this!
    Pool Noob
    16000 Gal Inground
    Jacuzzi Magnum Pump
    Sand Filter
    Jandy LT400 Heater
    Jul 2015
    discovery Bay, Ca
    36
    Re: Jandy LT400
    Just my two cents ...... sell it, give it away, junk it ....... save the hassles .... and buy a new one. You mentioned you are already frustrated and it seems that you are having some other work done so add another $1K to the renovation.
    20x32 in ground gunite with white plaster, 17,000 gal apx. kidney shape, and spa attached, solar, 6 panels 4x10, pentair equipment: pump intelliflo vs 8x160VS, cartridge filter 420sq, gas heater, master temp 400k but, easy touch system pool/spa 4sc-ic40/ with salt system, easytouch wireless controller 4 circuit and Rebel auto cleaner. Taylor K 2005-C completed June 2015.
    Re: Jandy LT400
    Post pics of the board and wiring
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    Re: Jandy LT400
    Before it was unhooked from your friends pool/spa, did you make sure it worked?
    Sorry Ive been busy on another business venture I am starting up.
    Paul
