Thread: Service-Timed Mode
    Apr 2015
    Pasadena, CA
    56
    Service-Timed Mode
    Hi all. Can someone double check if I'm understanding Service-Timed Mode on my Hayward automation system correctly? Assuming my pump is set to run everyday from 7pm to 3am, if I put the system in STM and turn the pump on at 8am, my understanding is it will run for 3 hours and then turn pump off at 11am, and then come back on at the normal time of 7pm. Is this correct? I want to know that the pump will not be running all day if I need to turn on in the morning to get extra cleaning time after a storm, if if I want to add acid in the morning. Does it matter if I turn the pump on first, or should I put the system in STM first? The manual does a poor job at explaining how to use exactly. Thanks.
    22,000 gallon IG plaster pool, raised spa w/spillover, variable speed EcoStar pump, natural gas heater, 60 SF DE filter, SWG (all Hayward), AquaLogic automated controller, Kreepy Krawly, TF-100 Test Kit
    Re: Service-Timed Mode
    Quote Originally Posted by thomearl View Post
    Correct.
    After 3 hours, the service timed mode will automatically switch back to normal automated operation and operate according to the set timers.
    Put it in STM first, and then turn on the filter. I think that if you turn the pump on first, it might stay on after STM because it was turned on during automatic mode.
    Support the site
    Apr 2015
    Pasadena, CA
    56
    Great. Thanks for your help!
