Thread: MPS and CC with DPD and FAS-DPD test
    Mar 2015
    Georgia
    157
    I'm seeing MPS will show up as CC in a DPD test and FC in a FAS-DPD test.
    http://www.troublefreepool.com/threa...l=1#post694546
    What I can't find an answer to is whether or not MPS shows up as CC in the FAS-DPD test?
    16k AG Vinyl Sand Filter
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: MPS and CC with DPD and FAS-DPD test
    It can show up as either depending on whether there is any chlorine in the water sample. There are two possibilities:
    Chlorine in water ---> DPD dye turns pink ---> FAS drops added but react with MPS ---> result is that MPS gets recorded as part of FC
    No chlorine in water ---> DPD dye remains clear ---> R-0003 added, reacts with MPS, and sample turns pink ---> FAS drops added to turn to clear ---> result is that MPS gets recorded as CC
    Basically, MPS doesn't react directly with DPD (at least not noticeably enough to produce a color) except at higher MPS concentrations. However, it does react with the FAS drops used for titrating FC and it reacts with the R-0003 potassium iodide used in the CC part of the test. However, if the MPS reacts with FAS during the FC part of the test, it only gets recorded there since there will be none left during the CC part of the test.
    In a regular DPD (not FAS-DPD) chlorine test, the MPS shows up as CC (unless the MPS is at very high concentrations):
    Chlorine or no Chlorine ---> DPD dye turns pink or stays clear ---> R-0003 added, reacts with MPS, and sample turns pink ---> result is that MPS gets recorded in TC (so as CC=TC-FC)
    Mar 2015
    Georgia
    157
    Ok. That was a good explanation. Thanks.
    Jun 2015
    Santa Fe Springs, California
    13
    Just FYI, Taylor makes a kit to neutralize MPS for the FAS-DPD test. It's kind of expensive (about $30), and an extra step during testing. After using the pool store method for a few months and dumping half a bucket of fresh n clear MPS into my pool, I bought the kit to make sure I'm getting proper FC and CC readings now that I'm doing the TFP method
    18,500K IG plaster, Pentair FNS+60 DE filter, Pentair Intelliflo VF 3HP, no SWG, Taylor K-2006-C, in Southern California (harsh water restrictions)
    Mar 2007
    San Rafael, CA USA
    12,082
    That would be the Taylor K-2042.
    Mar 2015
    Georgia
    157
    Yes I saw about the Taylor kit. I don't use MPS. I was just doing a little research on it. Thanks.
