I recently had a leak after the pump to the filter when I was at work. I came home and the pump had been running for 5 hours possibly with the leak. I replaced old pvc with the new this afternoon. I fired up the pump and there is now no suction which is causing pool to not circulate. I tried the hose in the pump basket, switching to spa only and everything possible and still no prime.
What can be done bc everything was running perfect until the leak we had yesterday from the original piping that is 8 years old.
I would Assume that if the pump was bad the motor wouldn't work. Thoughts?
