Page 1 of 4 1234 LastLast
Results 1 to 20 of 79
Thread: Perplexed and frustrated. Please help!
    Jul 2015
    Northern IL
    42
    We bought our house recently and are first time pool owners. There's direct sunlight on the pool from around 7 am until around 7:30 pm. We have come across several issues with trying to open our pool but finally had it going (the CYA was 30 and FC was 3 according to Leslie's). This past weekend (Saturday) we had a party with several swimmers who spent the entire day in the pool. By Monday our CYA and FC both dropped to 0 (again according to Leslie's) so we added 4 quarts of Instant Pool Conditioner. By Tuesday the water was tinted neon green but I could still see the bottom of the pool. Today, the green is much darker and I cannot see the bottom. My husband has finally agreed to let me take over and become a "mad scientist". I tested the water today (first time with Taylor K2006) and the levels are below.
    FC - 0
    PH - 8
    TA - 80
    CH - 150
    CYA - undetectable (below 30)
    Since we just added the conditioner on Monday, should I be waiting to test the CYA?
    Any ideas on why our pool water turned green after we added the conditioner?
    Any help would be GREATLY appreciated. We've only been able to use the pool a handful of times and it's already the end of July.
    15 x 30 above ground, SunRunner sand filter, SunRunner 1.5HP SPL Pool Pump
    TFTestkits, CYA Chart, Recommended Levels, SLAM, OCLT, Posting Photos
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Perplexed and frustrated. Please help!
    Welcome to TFP! I'm sure you will do a much better job maintaining your pool than the pool store.
    If it was liquid CYA then no reason to wait to test. Your pool was about to turn green no matter what you did. Algae was already growing in the pool due to lack of chlorine. A cloudy pool is the first sign of an algae bloom, then slimy, then green. Also, the CYA is gone due to lack of chlorine, bacteria will consume your CYA in low chlorine conditions. Which makes it worse because the sun will burn up chlorine faster.
    It is very important to keep the chlorine at or above target level for your CYA at all times, Chlorine CYA Chart. If it ever drops below minimum the pool is unsanitary and algae will start growing.
    Adequate chlorine is especially important when lots of people are swimming or you are swimming all day. When we are planning to swim a lot we raise FC to 10ish before we swim, again after we swim and then double check again a few hours later. If you are swimming all day long take a mid-afternoon FC check and raise it with a dose of bleach if it is low. The point is to keep it at or above target at all times. It is safe to swim with FC up to shock level for your CYA. It is not safe to swim with FC below minimum because the pool is not properly sanitized.
    So, now you have some algae in the pool. Time to Pool School - SLAM - Shock Level And Maintain the pool to kill the algae.
    Also, check out the Pool School - ABCs of Pool Water Chemistry
    Jul 2015
    Northern IL
    42
    Thank you pooldv. I just want to make sure that I am going to do this right since it is my first time. In order to SLAM the pool with the measurements listed in my previous post, I first need to lower my Ph. Then SLAM the pool with chlorine. Then, once the SLAM process is finished, I should raise the CYA? If the CYA is so low that it's undetectable, will I even be able to raise the FC to the appropriate shock level and maintain it?
    Aug 2014
    Northern IL
    4,615
    Hey, fellow Northern Illinoisian! Welcome!
    Go ahead and buy some more liquid conditioner (faster fix although more expensive than other types) to bring you up to about 40 CYA. Buy enough for 40, but only add to 20 (poolmath) as you don't want to overshoot and you may well have some in there already from your first addition. I have my CYA between 30-40 and it seems to work well in my pool and our climate.
    Do you have some muriatic acid? Use it safely (ask if you don't know how) to lower your pH to the low 7's.
    After your CYA is at least 30 and pH is down, start your slam.
    Ask questions whenever you have them!
    Last edited by MarianParoo; 07-22-2015 at 11:46 PM. Reason: Whoops! Said don't add....
    DFW, TX
    24,514
    There you go, MP has you moving in the right direction.
    Here is a very handy page about pool chemicals, what they are, what they do and how to add them.
    Jul 2015
    Northern IL
    42
    Ok. Any suggestions on the best tool to use measuring out these chemicals?
    seeing as how plastic is porous and I'd like to be able to store and reuse the measurement tool, do you suggest plastic, glass, or something else?
    DFW, TX
    24,514
    No glass around the pool. I usually just estimate. I have used a plastic measuring cup and a kitchen scale occasionally to be more precise. But, most of the time I just round it to the nearest 1/4 jug or so. For my hot tub I do have a plastic 1/4 cup and a plastic teaspoon that sit with my hot tub stuff because the chemical doses are so much smaller. Your pool is relatively small so a plastic measuring cup would be good to have. Poolmath reports most things in volume and weight so you can just use the volume measurement and a measuring cup for dry things as well.
    Jun 2015
    The Woodlands TX
    26
    The test strips are nice but if thats what you're using to test you should know they're not very accurate with CYA. I assume this because you tested zero CYA.
    25k IG Gunite and failing quartz over plaster, BBB and considering SWG, Hayward DE 60 filter, Hayward 400k heater, Boost-Rite pump to Polaris, Pentair filter pump, Hayward waterfall pump
    jasnovanorder's Avatar
    Jul 2015
    Hamilton Michigan
    201
    Welcome! To start you should focus on bringing your CYA up to between 30-40 and lowering your pH to between 7.2-7.5. With the amount of sun your pool sees its very important to get your CYA up to the correct levels. Between the sun and the algae any chlorine you add will get eaten up almost instantly if you dont have the correct amount of CYA. While waiting for the CYA to raise go out and get a mess of regular bleach. Your going to need it. As for a measurement tool I use a glass 1 cup measuring cup with a string to put around my wrist so i can drop it. (like the nintendo wii remotes) but I have a fairly small pool so that just works the best for me. Good luck and feel free to post some pics so we can follow along on your new pool owning adventure
    Intex AG metal frame vinyl sides 10,400 gal. 3000 gph intex pump with 16" sand filter
    My Slam
    Aug 2014
    Northern IL
    4,615
    Guesstimate on the MA, don't measure. Use less than you think you need. You can always add more. I use a plastic measuring cup for my bleach. It has a pouring spout that helps with splashing.
    Jul 2015
    Northern IL
    42
    I added the muriatic acid and 1 hour later, my pH still looks the same. I added a picture but not sure if I did it right. Do I add more acid?
    Aug 2014
    Northern IL
    4,615
    Yup. Do about as much or a bit more as last time. You can retest about a half hour later and see where you are.
    Jul 2015
    Northern IL
    42
    Will I get (am I getting) an accurate pH reading with the algae issue?
    DFW, TX
    24,514
    The PH is off the scale so no telling how high it really is. Add the same amount of acid, let it mix 15 or 20 minutes with the pump running and test again until it show lower on the test.
    Quote Originally Posted by Sshymanik View Post
    Yes, the only thing that interferes with the PH test is if the chlorine level is above 10.
    Aug 2014
    Northern IL
    4,615
    While we're waiting on the pH results, I am wondering. Did you get a K-2006 C or A? (Are your reagent bottles 2oz or 0.75oz?)
    Sandra B's Avatar
    Aug 2011
    Shreveport, LA
    103
    I have a plastic 64 oz clear paint bucket from Lowes that I measure my MA into. It's marked ounces on one side, litres on the other. Never had any issues using it and I've been using the same one for 3-4 years. It's nice using this size because I usually only add 16-24 oz MA, so it only fills up a couple inches which is about a fifth of the volume, so lots of space for the fumes to dissipate and to hold and pour.
    18,000 gallon freeform inground plaster
    Jandy 1.5 hp pump & .75 hp booster pump
    Aquapure SWG
    Pentair Triton II sand filter
    Legend pressure-side vacuum
    Jul 2015
    Northern IL
    42
    Quote Originally Posted by MarianParoo View Post
    The kit just says K-2006. And the reagent bottles are .75. I think I remembered there being comments about there being something different about the k-2006c. So when I ordered the kit I made sure it was labeled k-2006 and NOT k-2006c.
    Jul 2015
    Northern IL
    42
    YAY!!! I am finally making process. Looks like a 7.4!?!? Should I try to lower it just a tad more before correcting the CYA?
    Aug 2014
    Northern IL
    4,615
    Your CYA/stabilizer can be added anytime regardless of pH. Did you get liquid or granular?
    Okay. Not sure where your read A was better than C, but be prepared to buy more reagents. The 0.75 bottles won't last long. 00871 especially.
    A tad more MA wouldn't hurt. Just a TAD!!! Low pH is one of the biggest no-no's!!!
    2nd question: what does your water currently look like?
  20. Back To Top    #20
    Sep 2013
    Connecticut
    728
    CYA, being an acid, will further lower the pH somewhat when you add it, so keep that in mind.
    If you haven't played with PoolMath yet, take a look down near the bottom of that page - there is a very useful function where you can see the effects of adding specified amounts of various pool chemicals (be sure to enter your pool volume up at the top first). That way you can predict what your planned CYA addition is likely to do to pH.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
