Results 1 to 8 of 8
Thread: "Restarting"---here's my numbers
    Hi all,
    I posted in the "getting started" forum the other day that it's been a while since I've been on here, but I'm back and ready to reclaim our pool. Our SWG has given up the ghost, so the pool guy we had was using tabs and probably some liquid chlorine. We're taking back the maintenance though.
    I ordered a refill test kit and all my components came today, so here's what I've got:
    CL < .5
    pH 7.8
    TA 130
    CH 230
    CYA 55
    I know those numbers are all a little off. But what do i fix first???????
    Sunny SW Florida! Uncaged Free-form IG pool, Pebble-tec finish, 20,000 gallons?? (Beach entry/tanning ledge is 9' x 9'; it's free form 37' x 19'. Depth 3 feet to max 5.5 feet. There's also an attached spa with spillover: 6 foot radius. Anything else?)
    Prologic computerized thingie with SWG; 1.5 hp Hayward II Super pump, cartridge (i think) filter. (Hubby contracted the whole thing...so I don't have a detailed list on what we've got!)
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: "Restarting"---here's my numbers
    You can use PoolMath to determine chemical additions. You put your volume in PoolMath at the top, then all your current readings in the first column and your target numbers in the second. It will tell you how much of what you need to add to reach that goal.
    First thing you need is some chlorine. Regular bleach (8.25%) or "liquid shock" chlorinating liquid (10% or 12%) to bring the level up to at least 6 or 7.
    Spend some time studying Pool School and you'll become a pro at this. You should also consider fixing or replacing the SWG.
    chiefwej
    Jan 2012
    'burbs of Augusta, Georgia
    7,359
    You should raise your FC level up to correlate with your CYA level using this chart--> Pool School - Chlorine / CYA Chart
    So for a non-swg pool, you need at *least* 5ppm FC, 7ppm would be better, and 9 might cover your loss until the next time you test. You never want to go below 5 or you're inviting algae in the door.
    How's your water look?
    Aug 2013
    Arab, Alabama
    422
    Can you gives us a CC level? As above, what does your water look like? Other than your FC and CH, your levels look pretty good!
    39YO 13K gallon former SWAMP/MONEY PIT, concrete bottom/Fiberglass Walls, Ecotech VS pump, Hayward Sand Filter, Dolphin DX5 Plus, Loop-Loc safety cover and YES, I have a TFT-100 test kit!
    Shock Level and Maintain - CL/CYA Chart
    I guess I didnt post my numbers well...by both tests (the yellow liquid in the block tester AND the DPD Powder) show a less than 1. So virtually no chlorine.
    Amazingly, my water looks clear....and we've had a lot of rain and it's Hot!!!
    I'll head to pool school and see what I need to add to bring it up.
    Thank you!
    Jan 2012
    7,359
    Quote Originally Posted by graffster View Post
    Thank you!
    You need to add liquid chlorine, STAT! Don't wait for the SWG to bring your FC level up, do it yourself now with regular household bleach if you've got it. Per my math that comes up to be almost two full gallons of 8.25% bleach, then you can let your SWG maintain it.
    If you don't do it tonight you're seriously risking a major algae outbreak.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    +1 to sooner is better than later. FC should always be at target level for your CYA, Chlorine CYA Chart
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,549
    FC up follow in 30 mins. with PH down.
    Do an OCLT to see if you need to do a SLAM. Links below.
    Pool School - Perform the Overnight FC Loss Test (OCLT)
    Pool School - SLAM - Shock Level And Maintain
    Let us know how that goes.
    Your TA will be last after everything else is balanced.
    Kim
