Results 1 to 11 of 11
Thread: Need HELP!! TFP For life new member!
    Jul 2015
    East Moline, Il. 61244
    2
    Exclamation Need HELP!! TFP For life new member!
    First of all I would like to say this is the best pool web site / forum out there, and I am now glad to be a part of it, and now a lifetime member. I bought a house on foreclosure with a pool that had trees and everything else growing out of it. (Pictures before and after to come). Ill keep it short. But I am a plumber by trade and deal with water and water balance for a living. Im not going to lie, the pool chemistry thing has got me stumped. I have spent hundreds of dollars at the pool chemical stores. I am done with it. I had a good friend of mine Zappafan, lead me in the right direction. I have had some good test results, but I seem to always have a issue with high Total Alkalinity and high PH. And it seems like over time, more things are getting out of balance. I have used over 35 pounds of PH reducer and at least 8 gallons of Muriatic Acid. Don't hold that against me, I was just going by what the pool store told me to do. I have a lot of money invested (as you all know being a pool owner) and just want to make things right and make my pool safe for my family and friends. Please see below my latest test results from my TF 100 Kit. And as always you guys are awesome and thanks in advance. If you have the time PLEASE HELP!
    -FC 5
    -CC of TC 1
    -PH 8.2>
    -TA 230
    -CA 575
    -CYA 20
    25k gal, IG Vinyl lined, Crystal Water DE Filter, 1HP Century Centurion pump, New in Sept of 14', Intellichlor SWCG, Filled by well. TF 100 with speed stir test kit. Taylor K 1766 salt test kit. Looking forward to a trouble free pool!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: Need HELP!! TFP For life new member!
    Welcome, and thank you for supporting the forum. First things first. What is the TA and PH of your FILL water?
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    You need to use PoolMath to determine chemical additions. That pH needs to come down. It should always be kept in the 7.x range. You put your volume in PoolMath at the top, then all your current readings in the first column and your target numbers in the second. It will tell you how much of what you need to add to reach that goal. Re the pH, you can start out with a full gallon of full strength (31%) MA. Once the pH is balanced, you need to bring the CYA level up. A 60-70 range is a good start with a SWG pool. If you don't have any CYA, look for it labeled as stabilizer. The TA will come down when you lower the pH. The CH is high but shouldn't be an issue in a vinyl lined pool.
    Spend some time studying Pool School (upper right button in this page) and all this will begin to make sense. At least you are getting a much easier start than those who come here because they have a pool filled with black or green water and slime. Welcome to TFP.
    chiefwej
    Zappafan's Avatar
    Aug 2014
    Hampton, IL.
    151
    Your on the right path. There are a lot of good folks here that will help you get that pool into shape.
    17K Gallon,IG Vinyl,1hp Pentair Challenger,Pentair TA60 Sand Filter, Hayward Colorlogic,Re-lined 06-20-15, TF-100,SpeedStir,Lagunitas and Margaritas. Zappafan Pool Build
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    I've been meaning to ask, Frank, Dweezil, or Moonunit?
    Jul 2015
    2
    Thanks for the quick response, I think you are on to something. My Total Alkalinity is 630 with a PH of 7.2 from my fill source. I took the water sample straight from my well pump pressure tank before it enters my water softener.
    Zappafan's Avatar
    Aug 2014
    Hampton, IL.
    151
    Quote Originally Posted by pabeader View Post
    The entire clan. Going to see Dweezil again in a couple of months. Can't wait taking my oldest 14 for his second Zappa plays Zappa show and taking my youngest 11 to his first.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Sweet! Grew up on Frank! Jammin' in Joes' garage. Amongst other 'interesting' creations such as (T&B) by a super creative mind.
    We now return you to your regularly scheduled thread content.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Zappafan's Avatar
    Aug 2014
    Hampton, IL.
    151
    Yeah we gotta get John some help.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Welcome
    With fill water TA that high it's going to take time to bring it down and PH will rise until you get TA down to around 100. And anytime you top off you'll be putting TA back in. If you can top off with rain water that will help. When I drain down for the winter I try to let snow and rain refill the pool in the spring to try to keep TA in check. Using MA to knock PH down will slowly bring TA down, you can speed it along by taking PH to the low side and aerating the water to drive PH up quickly and repeat until things stabilize.Though my TA isn't as high as yours I know it's something I have to deal with and it doesn't bother me.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Zappafan's Avatar
    Aug 2014
    Hampton, IL.
    151
    John,
    How are your readings today? Did you start the TA reduction procedure http://www.troublefreepool.com/pool-...l%20alkalinity?
