Thread: Pump housing leaking
    Jul 2015
    Alief
    3
    Unhappy Pump housing leaking
    I've read some threads about leaky pump housings. I'm not sure what type of pump it is, but I can see that there's a leak a the location in the picture.
    This is a pic at the front of the impeller housing. I can see water and air-bubbles from the top of silver connector.
    Any one have any ideas how to repair this fitting?
    Thanks in advance
    Nopoolguy
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Pump housing leaking
    Can you take a picture of the pump data plate. You may have to cut the piping and redo the connection. You may want to use a union connection in the future.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,318
    turn it off, dry it, then try to unthread it.
    If that is a threaded you might only need some plumbing tape to fix.
    Dolphin E10 Cleaning Robot.
    Jul 2015
    Alief
    3
    Red face Re: Pump housing leaking
    Quote Originally Posted by bobodaclown View Post
    Hey folks, I really appreciate everyone's response.
    Here's a pic of the pump data plate.
    Cheers
    NoPoolGuy
    Jul 2015
    Alief
    3
    Quote Originally Posted by nopoolguy View Post
    Cheers
    NoPoolGuy
    Well, I finally got frustrated enough to cut the darn thing off. Yipeee, it's threaded in the pump housing. Now to just get a PVC to make the connection and some pool pipe-glue and I'm good to go.
    Thanks for all the input.
    Cheers
