Results 1 to 11 of 11
Thread: This little guy died in my pool today, do I need to add extra chlorine?
    Mar 2015
    Las Vegas NV
    460
    Didn't know where to post this but thought since we deal with chemicals here, might not be a bad place to start, Mod please feel free to relocate if necessary. He wasn't in there long, tops a couple of hours. Should I toss in some extra bleach just to be careful?
    My water sure is clear isn't it? I thought these little buggers could swim . . .
    SUMMER 2015 BUILD IG gunite 38 x 31, 28,000 gal, 110' perimeter, Intelliflo VS, Whisperflow 3hp, Intellibrite LED x2, Clean & Clear 520, Screen Logic, Intelichlor 40, Quartzscape Blue, K-2006C, Speedstir, Aquanaut 400 (4 wheel The Pool Cleaner)
    May 2015
    Chickasha, OK
    184
    Re: This little guy died in my pool today, do I need to add extra chlorine?
    I found a dead rat in my pool (resting comfortably on the main drain) a couple weeks ago. He'd been there up to 24 hours...
    I thought surely I'd see some CC or at least a drop in FC as a result, but my tests showed nothing other than the normal FC loss due to sunlight. I added the amount of bleach my tests called for, and all is well.
    25,000 gallon freeform gunnite/plaster, built in the 1970s/80s; Sta-Rite 9463004 575-lb. sand filter; Sta-Rite DuraGlas/Max-E-Glas (P2RA5F-125L) single-speed 1.5 HP pump, manufactured 12/1993 (1M93M).
    Helpful links: TFTestKits; Pool School; ABCs of Pool Water Chemistry; Chlorine/CYA Chart; PoolMath; SLAM - Shock Level And Maintain
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    If it hasn't been decomposing in full sun for days/weeks on end I would think it's ok as long your chlorine levels are good.
    I get squirrels all the time, leaning over the coping to get a drink, some times even when I'm floating in the pool, makes me laugh.
    this poor guy must have lost his balance.
    Dolphin E10 Cleaning Robot.
    Apr 2015
    Quinlan, tx
    811
    I'm a germ a phobe, I'd add some extra bleach
    Lisa P.
    26,000 IG, pebble tec, flagstone, pentair Triton II TR100 sand filter & VS+SVRS 3hp multi-speed pump, Intellichlor IC-40 SWG, Pentair Booster Cleaner, spillover spa, waterfall, Taylor K-2006 testkit
    [It is better to know how to learn, than to know. - Dr. Seuss[/I]
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Pool looks great. Won't hurt anything to bump FC to 10. Probably don't need to but why not.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    I would just test and see if your FC and CC is good. If it is, go on about doing whatever you were doing.
    Poor lil dude. I know its gonna happen to me some day because i hve lots of squirrels in the yard. But when it does, Im gonna hate it.
    I like my squirrels and I even feed them now and then.
    Divin Dave,
    Mar 2015
    Las Vegas NV
    460
    Just looked out the window and I've got four boys in my pool, too late . . . I'll post if anyone gets sick or starts storing nuts.
    DFW, TX
    24,450
    LOL!!!
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Quote Originally Posted by QingGuy View Post
    They can...but it takes a lot of energy. If they can't find their way out, they are just like us...and I haven't found any pool schools for squirrels to teach them to float. Poor guy was probably trying as hard as he could. RIP buddy.
    15' x 29' 10,300 gal w/ spa, IG-Plaster (Stonescapes Tropics Blue), 2spd WhisperFlo pump (1.5hp WFDS-26), Pentair Clean and Clear CC200 cartridge filter, Pentair MasterTemp 300BTU heater, Clear o3, RS-8 iAqualink
    Orlando, FL
    690
    I came home to that scene once. I was so glad the kids were not here. I dumped chlorine, ran the pump 24/7 for a few days. I have gotten rid of that pool but will never tell the kids.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    May 2015
    Chickasha, OK
    184
    I wonder if a FrogLog would support a chipmunk/squirrel...
    I'm tired of finding frogs in my skimmers, so I'm considering ordering 2 of them.
