Results 1 to 9 of 9
Thread: Dropping Chlorine Values
    Jun 2015
    Houston, TX
    89
    All,
    Ok I run a Liquidator no check valves (raised off the ground) on my AGP, Hayward pump and Sand filter. Water has been crystal clear since day 1, however I am loosing Chlorine in the pool very rapidly.
    Here are my numbers from Sunday morning'
    FC=0, CC=0, pH 8.4 (I run a spray wand to cool),CYA 80, TA 110.
    I added liquid bleach 12.5% to bring my FC up to 6.
    Tuesday I checked FC it was 4, I just checked the FC and its 1.
    I know the liquidator is working as I see fluid movement, the meter shows the ball between 3 and 4, I have 6-8" yellow coloration in the bottom of the unit.
    What am I missing or not understanding?
    Pool gets direct sun from 8:30am till 5:30 pm, I run the pump from 8 pm to 8 am.
    John
    AquaMaster Deluxe 8000 AGP, 5500 gallons, 12x18. Liquidator and Pool Rover JR.
    1st Pool so go easy on me I'm using a TF 100.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Dropping Chlorine Values
    Seems like you are on the verge of an algae bloom. That is the number 1 cause of high unexpected chlorine loss. What is you CYA?
    Ellington, CT
    262
    Oops didn't see that you said you ran your pump for 12 hrs
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Your Cya is high, and adding for 6PPM FC won't be enough for 80. I betting you've been low for that Cya a lot recently, and you are likely on the verge of a bloom as poolDV says.
    Essential Links:
    DFW, TX
    24,497
    Oops, missed CYA is 80. Chlorine level is set based on CYA and the Chlorine CYA Chart. Target FC for 80 is 9ppm. That means FC should be at 9 or higher at all times to keep your pool sanitized and algae free. And any time it drops below 6 algae will be growing and the pool will be unsanitary. Especially in hot sunny Houston
    Jun 2015
    Houston, TX
    89
    If I add bleach to get FC up to 9 the chemical smell is very strong.
    Do I just ignore it?
    Thanks all.
    John
    Jun 2015
    Houston, TX
    89
    Update,
    I was starting to wonder if my bleach was still at 12.5%, so after doing a lot of reading and digging I found the test method.
    Well what started at 12.5% is now 4%, so where I would add say a 64oz heck I needed to actually add a gallon.
    Oh well, what should have been a cost savings by splitting a drum with another member might have actually cost me.
    Live and learn, I am going now to buy some fresh bleach now and start monitoring it again.
    I do have a question for those who buy in larger quantity, how do you store the bleach and have you had it gass off in less than 2 months!
    John
    DFW, TX
    24,497
    Bleach needs to be stored inside in the A/C out of the sun. Laundry room, pantry, etc.
    The smell you were smelling was CC, combined chlorine, that is your chlorine killing algae. For now, that is a good smell!
    Jun 2015
    Houston, TX
    89
    Quote Originally Posted by pooldv View Post
    So my garage is not the ideal location...
    Thanks...
    John
