Thread: Pool Light - Unsure What I Need
    Apr 2014
    Central FL
    60
    Old light is too aged to read any info from. But, I have a transformer so I know I need a 12v light, and probably 50' of cord...
    But what wattage light? How do I determine this? Or is it just a matter of preference regarding the intensity of the light?
    I'm looking here at Pentair Amerlite. You can see toward the bottom of page there are different options for wattage.
    Thanks for help!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pool Light - Unsure What I Need
    How big is your pool and is this the only light?
    Essential Links:
    Apr 2014
    Central FL
    60
    16,000 gal I think, and yes only 1 light.
    Apr 2013
    Sacramento, CA
    2,769
    You are limited by your transformer. If you have a 100 watt transformer then you are limited to a 100 watt 12 volt bulb. If a 300 watt transformer then a 300 watt 12 volt bulb.
    I suspect you have a 300 watt transformer with a single light for the pool but check the transformer.
