Thread: Thermistor SL32 2R025 versus AS32 2R025
    Jul 2015
    Gilbertsville, KY
    1
    Are these the same product? My board has a AS32 2R025 but when I ordered it they shipped me SL32 2R025
    San Juan Pool Dolphin 14x33 inground fiberglass 11500 gallons Mineral Springs
    22,544
    Re: Thermistor SL32 2R025 versus AS32 2R025
    The AS and the SL units are interchangeable.
    May 2017
    Ponte Vedra Beach/FL.
    20
    Just did the repair on my SWG. Ordered the SL 32 based on the 2010 post that describes the process. When I took out the board (which I had replaced a few years ago) it has the AS 32 thermistor. I read somewhere on Digikey that the AS 32 is being used on the new boards and is stronger but I installed the SL 32 and it worked fine. Digikey didn't have the SL in stock so I had to go to amazon to get it. When I looked up the AS they had a couple of thousand in stock. The AS is $6.53 vs. $2.49 for the SL, so I assume there is some difference. Either way, thank you TFP, you saved me hundreds of dollars and I was up and running in a couple of days.
    16,500 gal concrete pool and spa. Pentair 2.6HP wisperflow pump; Pentair Quad 80 DE Filter; Currently no heater,
    but planning a Raypac Gas Heater shortly. A Hayward T15 SWG and an AA Mfg 1.5" 6 port Actuator cleaning system. 1 Jandy Valve Actuator at intake from pool or spa; 1 Jandy Valve Actuator return after heater to pool or spa.
    22,544
    Thanks for letting us know that it helped. And about the difference in the parts.
