Page 1 of 16 123411 ... LastLast
Results 1 to 20 of 306
Thread: Bakersfield, Ca Gunite Build
    Emersonsdad's Avatar
    Mar 2014
    Bakersfield, Ca
    152
    Breaking ground this Friday! Long time coming! Here's the sketch from the PB.
    20K gal 32'x24' 4 bubble free form gunite pool w/ Midnight Blue Quartzscapes
    8' deep/3 1/2' shallow w/ 2 benches, sun shelf, 4' sheer descent, 4 deck jets
    All Pentair Equipment- Intelliflo VS pump, Clean and Clear Plus 420 filter, Easytouch 8 w/Screen Logic Controller, IC40 Intellichlor SWG, Intellichem w/acid container, Intellibrite 5G Color LED pool & spa light, 2 Globrites
    Mar 2014
    Bakersfield, Ca
    152
    Re: Bakersfield, Ca Gunite Build
    All Pentair equipment
    Intelliflo VS pump
    Easytouch w/Screenlogic
    Intellibrite 5G Color LED light
    Mar 2014
    Bakersfield, Ca
    152
    Going with a dark blue Quartz finish. The pool will have 1 water curtain descent where the step up is on the back. I think I'm going to put 4 deckjets on the back side also. One question I do have is should I add more lighting besides the Intellbrite? Was thinking of the Globrites, 1 on each side where the 2nd step is and 2 on the back bench. Is that overkill? All opinions welcomed.
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Welcome to TFP
    With lighting it is generally advised to face them away from your house/patio.
    The glare will detract from the pool.
    I can see you would benefit from a 2nd light as the Intellibrite will struggle to light up the far end of the pool.
    A globrite to the right of your sunshelf would probably be enough, but a second intellibrite would be better with the dark quartz finish.
    You are looking for reflection off the target wall and some backscatter to enjoy the benefits of those multicolor LEDs.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Mar 2014
    Bakersfield, Ca
    152
    Thanx! Would a 2nd Intellibright be too much light for the shallow end of the pool or no such thing?
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    I would not say no such thing, but 3-1/2' deep and aiming down towards the back bench for the additional light.
    With that, the original light might be improved by moving it a little close to the sunshelf and aiming for the sheer descent.
    Apr 2013
    Sacramento, CA
    2,769
    Two lights on the house side of the pool would be much better that as planned. As shown if you swim laps at night you will be swimming directly into the light. Also standing at the shallow end you will look into the light.
    Mar 2014
    Bakersfield, Ca
    152
    I think I'll go with the Intellbrite in the deep end and 2 Globrites on the sun pad and 1 more Globrite in the shallow wall. Should be plenty of light that way.
    Mar 2014
    Bakersfield, Ca
    152
    Dig is complete!
    Mar 2014
    Bakersfield, Ca
    152
    Rebar is in.
    Mar 2014
    Bakersfield, Ca
    152
    Here's the tile and stone we picked out.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,636
    Nice job so far!
    Now go measure everything-----------is it deep enough, wide enough, tall enough, etc.
    Add in 3 inches for the gunite and plaster. NOW is the time for fixes if they are needed.
    When do you get the gunite done?
    Kim
    Mar 2014
    Bakersfield, Ca
    152
    Gunite is scheduled for Thursday with inspection today. We actually went 8' in the deep end. I'll take a tape measure to it today and check the dimensions. Thanx.
    Jul 2012
    Tallahassee, FL
    30,636
    Yeah best to look at it now. We had one about 3 weeks ago where they were making a tanning ledge and it was to be a beach entry! He saw it and they were able to fix it.
    Kim
    Mar 2014
    Bakersfield, Ca
    152
    After this convo I noticed the pool light was where the skimmer was supposed to be and vice versa. It was fixed today and also passed inspection. Gunite tomorrow!
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    Yep, check everything and be there as much as you can, just like any major project.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jul 2012
    Tallahassee, FL
    30,636
    It is TOMORROW!!!!!!!!!!!!!!! LOL
    Are you going to be able to be there to watch??
    Kim
    Mar 2014
    Bakersfield, Ca
    152
    Yeah. They should be here anytime.
    Mar 2014
    Bakersfield, Ca
    152
    And we have a pool! Well, almost....
  20. Back To Top    #20
    Jul 2012
    Tallahassee, FL
    30,636
    Now go bond with your pool and water it! Get it lots of love (water). You can use sprinklers if you want.
    I love how it looks! Great design!
    Kim
