Results 1 to 7 of 7
Thread: Shock deposits / lumps - will an acid wash cure this?
    Jul 2015
    Tempe, Az
    123
    Not sure if it was the previous owners being lazy, or the realtor not knowing pools, but it looks like i have lumps all over the pool caused by shock not dissolving properly? I'll try and get an underwater picture, but they are basically lumpy things that i can scrape off with a putty knife, and they dissolve. But, they are everywhere. They are gray with white hard deposits in the middle, and everywhere!!!!
    the pool needs a good acid wash anyway, but I can't do that for a couple months since it's so hot right now. Wondering if that will cure it? Maybe I'll try and carefully remove one and see if muriatic acid dissolves it.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Shock deposits / lumps - will an acid wash cure this?
    When you pull one out, save one, crush it, and see if smells strongly of Chlorine before you put on in acid. Let us know what you find, I'm sure others would be interested besides me.
    Essential Links:
    Jul 2015
    Tempe, Az
    123
    Will do Patrick - I'll try and get some pictures tonight. Need to test the new waterproof phone case anyway
    JoyfulNoise's Avatar
    May 2015
    13,193
    Brett_N,
    Just food-for-thought here - read user @OnBalance's post about calcium nodules. Since you did not control the pool prior to getting the house, there's no telling what was done previously. Calcium scaling is always a possibility.
    Good luck.
    Matt
    Jul 2015
    Tempe, Az
    123
    Thanks Joyful....hmm.....this may be what I have - but if it is, I'm screwed and may need to have the whole pool re-plastered. Yay.
    Jul 2015
    Huntingtown, MD
    79
    I used a pumice stone to knock away calcium "nodules" in my spa once before. They were on the spa seat and walls.....not real big. About the size of a sunflower seed kernel or less. My wife was happy because the calcium deposits were ruining the bottom of here expensive bathing suits. I'd need to maintain it about 1x per year.
    The pool was kept pretty well balanced (usually!!!).
    May 2015
    13,193
    Quote Originally Posted by mmcwhorter10 View Post
    That's not surprising. Spa water chemistry is easily thrown off and can become scaling. Usually you lower the pH and TA a bit before soaking to abate some of the pH rise.
    Matt
