Thread: Low Salt/pool turning yellow/green
    Cchcbuse's Avatar
    Jul 2015
    Birmingham, AL
    13
    I've added 35lbs of salt, turned the SWG off, and am leaving the regular pump running to dissolve the salt.
    Should I put regular Clorox in the pool? Or crazy question I know: Should we go ahead and turn the SWG back on and "boost" or it probably wouldn't work right until the salt dissolves?
    Pool owner since July 3, 2015
    AG Intex 16x48" Ultra Frame with filter pump
    5,061 gallons
    Intex 120V Krystal Clear Saltwater System
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Low Salt/pool turning yellow/green
    Always maintain your chlorine level at target level for your CYA, Chlorine CYA Chart or algae will grow and you will need to Pool School - SLAM - Shock Level And Maintain the pool to get rid of the algae.
    If the SWG isn't working or keeping up then by all means add bleach. I add bleach to my pool pretty often to keep chlorine above target.
    The salt will need some time and some brushing around to dissolve before it will clear the low salt error. Sometimes the Intex SWG gives a low salt error when the cell needs to be cleaned. So, depending on how old or how long it has been since it was cleaned you might check that first.
