Thread: Aqua Rite Pro - "check system" light on, LED only displays "Check System"
    Jul 2015
    Houston, Texas
    7
    I have an Aqua Rite Pro. The "Check System" light is lite and the LED only displays "Check System". If you push any of the buttons on the unit nothing happens. I have a pool guy (just bought the house and had no experience with pools) says I need a new board. When I called Hayward they asked if it was the control unit (part GLX-CTL-AR-PRO) or the PCB unit (GLX-PCB-AR-PRO). Does anybody know which part I need to purchase?
    Casey's Avatar
    SW PA
    10,461
    Re: Aqua Rite Pro - "check system" light on, LED only displays "Check System"
    Welcome to TFP!
    I'm not sure but someone else may know.
    Thimble's Avatar
    Apr 2013
    Wichita, KS
    93
    It may be as simple as your SWG needs cleaning. You can find directions in Pool School-Pool Equipment-Salt Water Chlorine Generators. Cleaning directions are included in the maintenance section.
    My Aqua Rite gives me a "check system" light about every 3 months. If I remember right, it does this automatically after X hours of operation as a reminder. I check the cell for build up ( which it never has), do a reset and it's good to go for another 3 months.
    I'm willing to bet yours is fine, it's just nagging you a little.
    15x30 IGP; 20,000 gallons; plaster
    Hayward SP2607X10 Pump; Purex Triton Tagelus Sand Filter
    Hayward Goldline T-Cell 15 SWG; Aquarite G1 Control
    Southwest Spas 400 gallon hot tub w/ozone
    TF 100 with speed stir
    Jul 2013
    Waxahachie, Tx.
    448
    I have an Aqua Rite, not a Pro. Mine does not have a "check system" light. I have an " inspect cell" light that comes on every 500 hours of operation as a reminder. To rest it I press and hold the diagnostic pushbutton for 3 sec's.
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
