Results 1 to 7 of 7
Thread: Soda Ash substitute
    Soda Ash substitute
    Can I use sodium hydroxide in lieu of soda ash?
    Laura
    Baltimore MD
    IG pool 25,000 gallons
    Cartridge filter
    Plaster pool
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Soda Ash substitute
    You sure can. Just be careful handling it. Pool Math does not have an automatic calculation for sodium hydroxide but you can get an estimate of how much to add using the Effects of adding chemicals section at the bottom of the page. It's listed there as "caustic soda" which is another name for sodium hydroxide or lye. Be sure to enter your actual pool volume at the top of the page before using the Effects section.
    Isolated Spa - 345 Gallons
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    How about Borax (Sodium borate) ?
    Are you trying to raise your pH?
    Great..thanks for your help
    Laura
    Baltimore MD
    Cartridge filter
    Plaster pool
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I'll emphasize care in handling of it. Liquid NaOH can hurt you very quickly, especially if it makes contact with your eyes.
    Essential Links:
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by Patrick_B View Post
    +1 I find it more hazardous than handling muriatic acid. The dry form that's usually only found in laboratories is even worse as it's very hygroscopic and generates lots of heat on contact with water.
    Mar 2007
    San Rafael, CA USA
    12,082
    If you want a direct substitute for soda ash (sodium carbonate), it is Arm & Hammer Super Washing Soda (careful: NOT the laundry detergent).
    20 Mule Team Borax raises the pH with about half the rise in TA compared to sodium carbonate. Lye (caustic soda) is more pure and doesn't increase borates. Aeration raises the pH with no change in TA.
