Thread: Very Pleased with Set Up
    Mar 2015
    Moncks Corner
    18
    It's been a month since I changed out the water in our hot tub - this was the first water change-out since we filled the new tub. Following the recommendations on this site I built a bromide bank (which I didn't do the first go 'round) and added Gentle Spa as well. All I can say is wow! Things have have been so steady and easily maintainable this time. My pH has been steady and the Frog floater has actually worked and maintains a nice steady Br level - even when we went out of town for 5 days. The Gentle Spa has made the water more pleasant feeling too. All I do is add MPS at a rate of 1.8 oz per hour of use and toss in a couple ounces of 8.25% bleach once a week.
    Current levels are:
    Br = 4 minimum
    pH = 7.6 and I haven't tweaked it once after the fill adjustment
    TA = 60 and I haven't adjusted it either
    CH = 140 steady
    This gives me a CSI of -0.2 per the Taylor Watergram.
    I think all the levels are decent though the TA and CH are a little lower than the standard "recommendations" that I tried to maintain during the first fill. Thanks for all the advice here and holler if anyone sees a level I should be concerned with....
    Thanks again for a great site/advice!
    Cheers
    Jacuzzi J-325 with ClearRay, outdoors, Bromine
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Very Pleased with Set Up
    everything looks good to me
    Mar 2007
    San Rafael, CA USA
    12,082
    If you have an acrylic spa (i.e. not plaster/gunite or with any exposed grout between tile) then you need not worry about the CSI except to not have it be high. Your numbers look fine.
    Mar 2015
    Moncks Corner
    18
    OK, cool. I've been checking it just to make sure everything is resulting in the right balance. I suppose if the numbers are all within range it almost has to be. My wife ribs me about my "chemistry set" that I dig out all the time but she likes the water being right!
