Thread: New to pool ownership
    Jul 2015
    Biloxi, ms
    4
    Pool builder turned owner the pool yesterday. I decided have the water tested at the pool store. Results are:
    alkalinity 80
    PH 7.7
    chlorine 0
    salt 2900
    Calcium 106
    stabilizer 6
    i don't have a test kit yet and the store person said to add 2 lbs of chlorine and 8 lbs of stabilizer. It is a salt pool. Any guidance?
    22k gunite, gray plaster,spillover spa, Breeze SWG, Jandy cartridge filter, Pentair 400,000 heater, Polaris 280.
    Jun 2014
    15,144
    Re: New to pool ownership
    Hey.... welcome! Some important links for you to read before you do anything else:
    Pool School - Start-up New Plaster (Still, follow your PB's recommendation to not void any warranty!)
    Pool School - Pool School
    Pool School - Chlorine / CYA Chart
    http://www.troublefreepool.com/calc.html
    TFTestkits.net (Definitely get the right test kit NOW!)
    So read these areas and let us know if you have any more questions. Congrats on the new pool! Welcome to TFP.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    One more page for your saltwater pool.
    Pool School - Water Balance for SWGs
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Quote Originally Posted by Schwartzv View Post
    alkalinity 80
    PH 7.7
    chlorine 0
    salt 2900
    Calcium 106
    stabilizer 6
    I wouldn't trust the pool store CYA results. So.... target 3 FC and add it using bleach until you get a test kit in your mitts. That's 3 quarts of standard 8.25% clorox or store brand bleach, every day. The sooner you get a test kit, the sooner you can get to work fin-tuning it all and possibly using the convenient powdered chlorine a while until the slat goes in and the SWG takes over.
