Thread: Installing Push/Pull valve for DE filter - PVC/ABS question
    Feb 2014
    CA
    24
    When installing a ABS Pentair push/pull valve to a PVC fitting, what glue should I be using?
    My plan was to use the Oatey red all-purpose glue on both fittings, and primer the PVC side only. Would this work fine?
    9000 gal IG chlorine fiberglass pool. Pentair FNS DE 60 sqft, Pentair 1.5HP SuperFlo VS, two 80 sqft solar panels, Taylor K2006 test kit
    Jun 2015
    Wildomar, California
    423
    Re: Installing Push/Pull valve for DE filter - PVC/ABS question
    I've always used regular pvc cement for abs backwash valves, over 100 in 30 years. Always worked well Make sure you prime all the fittings well.
