Thread: Underwater cure epoxy?
    Jul 2015
    Port Neches, TX
    53
    Hi All,
    Looking to see if anyone has a line on some type of epoxy that can cure underwater? I have a broken screw tab inside my my (spa) niche and would like to try and glue a "fender nut" over the remaining stub (if I can find one in stainless)...
    Attachment 40294
    Thanks!
    Russ
    15x30 18k gallon fiberglass "Lazy 8" inground pool, Aquarite 40k salt generator, 1 HP pump, Hayward DE filter, Barracuda G3 (side port) cleaner.
    DaneCE's Avatar
    Jul 2011
    VA
    279
    Re: Underwater cure epoxy?
    I bought this last year for a quick fix if needed. I haven't used any but it seems like a good option.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    the JB waterweld works well.
    Divin Dave,
    Atlas Minerals EpoxyBond Pool Putty works.
    Support the site
    Jul 2015
    Tempe, Az
    123
    Does the JB weld adhere to plaster? My kreepy krawler keeps yanking the pool light out since the housing plate is not fit correctly.
    Jul 2015
    Port Neches, TX
    53
    Quote Originally Posted by DaneCE View Post
    Thanks, I ordered some last night!
    Russ
