Thread: Have about 6 bags on Non - Chlorine Shock Left
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    Before I joined the wonderful TFP community, I followed the Pool Store advice, purchasing Phos Free, Chlorine Shock, Non-Chlorine Shock, etc. This did not last too long as I knew something was wrong.
    I gave my Phos-Free to the Pizza Man.
    Although, I still have about 6 bags of Non-Chlorine Shock (42.8% Potassium Peroxymonosulfate, Inert Ingridients 57.2% and Active Oxygen 4.5%).
    Each morning as I go and grab the liquid chlorine in the basement, I walk by these bags (They also used to cost $6 a bag) OUCH! I can purchase 2 gallons of 12.5% for the same price, which lasts me a good 4 days in real hot weather.
    Question: What should I do with the Non-Chlorine Shock? Could I use it? If so, under what conditions?
    Here are my current levels:
    FC 4-7 daily
    CC 0
    TA 110
    CYA 50
    CH 175
    Water is crystal clear. Only increased PH 1X this year and lowered PH 3X (slowly over 2 weeks) from 8.1 to 7.5. As the TA decreased, the PH has been more stable. Any change I get to lower the PH, I will as this will bring my TA to the levels that I need. Have not added anything else all year except liquid chlorine. If there is a day where activity will be high, I usually dose the pool with enough chlorine to add an additional 1.5 ppm daily. I actually have been monitoring my pool very closely to determine what is needed under most conditions, etc.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Have about 6 bags on Non - Chlorine Shock Left
    You could still use it as it is a good oxidizer, like bleach/chlorine but know that it will show up as CC when you test for several days after use. The problem is, you would have to balance your FC level with the additional use of MPS. In theory, you could use no bleach for a couple days and your FC + CC (registered by hopefully only MPS) would be your effective FC level but I'm not sure how that would work out.
    If it were me, I'd try to return them to where I purchased them for a refund or store credit on something you actually need. If that didn't work, try to sell on ebay, craigslist. If that didn't work, turn them in to a local household hazardous waste facility. Many of these facilities will have a "shopping" area where people can come in a get surrendered chemicals for free if they are still in proper containers and not a hazard. It could be very useful to someone with a hot tub or indoor pool.
    Isolated Spa - 345 Gallons
    rubone74's Avatar
    Jun 2015
    29
    I found small dead animals in my pool three days in a row (House Finch, Field Mouse, then another Field Mouse). On the third day I decided to test my CC level and it took two drops of the reagent to go back to clear. I added my daily dose of liquid chlorine and a bag of Leslie's Fresh 'N Clear non-chlorine shock. CC's were back to zero the next day. I was happy. Did the non-chlorine shock work by freeing up the FC or did the sun and liquid chlorine do the job for me? If so, you might still have a use for those bags.
    13K gal, inground, pebble, 3HP Pentair Intellipro VS pump, Sta-Rite System 3 cartridge filter, A&A infloor cleaning system, Taylor K2006 test kit. Build date 06/15.
    Mar 2007
    San Rafael, CA USA
    12,082
    Non-chlorine shock will oxidize some organics and while it can help prevent formation of some CCs by oxidizing some organics before chlorine reacts with them, it doesn't generally get rid of already existing CC's directly. What is more likely in your situation is that continued exposure to chlorine got rid of the CCs, especially when chlorine was exposed to sunlight since it breaks down into hydroxyl radicals that are very powerful though short-lived oxidizers.
    wjr75's Avatar
    Jun 2013
    IL
    836
    I have some left over from a few years ago and I will dump a bag in after a party to get the little kid possible factor
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
