Thread: Cloudy blue pool water
    Jul 2015
    Toledo Ohio
    1
    Hi, I have a 22 by 52 inch intex swimming pool went on vacation came back and the water was brown so my daughter and I went and bought 4 gallons of liquid chlorine and 4 bags of shock and we put in in last night a sun down. This morning we got up and it's a cloudy blue color we let some of the water out yesterday before we shocked it and stuff. I need to no how can I get it back clear. I'm a first time pool owner and I did go to Leslie and they try to push all them pool chemical over on you and I don't no nothing about them. PLEASE somebody help!!!!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Cloudy blue pool water
    Welcome to TFP!
    The way you beat it is by taking control yourself. This means educating yourself, and getting a proper test kit. You can't do this relying on pool store testing, which doesn't seem to appealing to you anyway. In your situation you'll need to SLAM, and the best buy for a test kit to do that is a TF100. The Taylor K2006 is also a good kit we suggest, but you'll need to order refills immediately as it won't have enough to complete a SLAM.
    See Pool School, and start with the ABCs. From there, read about the SLAM procedure while you wait on a kit to arrive. We give identical advice day in, day out for this situation, so it's the path I suggest you take. All the info and help you need is here on the forum, so ask questions as they arise. Post a new thread when you get the kit and full test numbers. Do this before you begin the SLAM, and we will be happy to help you.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP!
    Get one of the Recommended Test Kits, I use the TF100 from TFTestkits.net.
    When you get it give us some test results and get ready to SLAM Your Pool.
    Here are some of my fave Pool School articles to check out.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    Hello and Welcome to TFP
    Patrick is one of the many pros around here. Follow his advice and you'll have a clean and sparkling pool that you and your daughter can enjoy and maintain yourselves.
    And a bonus, you'll never have to go to the pool store again!
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
