Thread: Filter troubles
    Jul 2015
    Central Pennsylvania
    2
    Filter troubles
    Hello everyone. I am new to the forum. I have a 150lb Hayward sand filter. My problem is that when i swept the pool all the algae that was on the bottom didnt filter out. It just blew back into the pool thru the return jet. Also when I back flush the filter the water goes thru the waste hose and the return jet which puts the nasty stuff right back into the pool. Any ideas on what my problem could be. Filter is about 4 years old.
    thanks
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    Re: Filter troubles
    Welcome.. Sounds like you should check the O ring under the multi valve.
    Jul 2015
    2
    Re: Filter troubles
    Got it fixed. It was the spider gasket on the multi valve
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    Re: Filter troubles
    Just to add, algae if visible is better shocked, killed and wasted not filtered.
    Seasonal World rectangular pool, 27K gallons (data sheet), 25.3K calculated
    Jandy Stealth JHPU 2.0 PUMP, 2HP
    Jandy CL340 cartridge filter
    Pentair C320 inline chlorinator
    AquaComfort heatpump heater
