Results 1 to 9 of 9
Thread: Large dark areas on liner floor of pool
    Central Connecticut
    159
    All though I am not new to pool care, I wasn't sure where to post this issue. In the center of the picture (attached), you'll see the stains on the pool floor. I tried brushing, vacuuming and rubbing them out. Won't go away. My pool readings are in good shape.
    FC 6.0
    CC 0
    TC 6
    PH 7.5
    TA 110
    Any idea what it can be and how to get rid of it?
    Rich
    18x36 IG 26,000 gal, Vinyl Liner, 24" Sand filter Hayward S224T, Jandy AE3000 heatpump and 1.5 HP SuperPump. Circupool RJ45 SWG
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Large dark areas on liner floor of pool
    Is this a liner pool or plaster?
    Jun 2014
    15,243
    Rich, would you mind also showing your CYA reading please?
    Central Connecticut
    159
    CYA is 55 and the pool is a liner
    Thx
    CYA was running low at about 40. Just boosted to 55. I'd like to get it even a little higher. Started noticing the areas last summer. CYA almost 0 when I open pool each spring.
    Central Connecticut
    159
    Liner
    Jun 2014
    15,243
    Depending upon the type of stain it is, you might like to try a Magic Eraser or try placing a vitamin C tablet on the stain and see if that does anything. Some folks will also try crushing the cheap vitamin C tabs (ascorbic acid) in a sock and setting it on the stain for a few minutes. Maybe one of those will work for you? Let us know how it turns-out.
    Central Connecticut
    159
    It's some fairly large areas, so I will try the magic eraser first. Any ideas on what causes these types of stains? Something I need to do differently or change ?
    Central Connecticut
    159
    Is it possible to be coming from underneath the liner ?
    Central Connecticut
    159
    The magic cleaner didn't remove the stain. It did however make it less "slippery" ... if that means anything
