Every year around this time, I seem to get a whisp of greenish , yellow on the shallow end bottom. My CHL reading right now is 15 and hasnt been below 8ppm this season and i did a drop test with NO DROP Pollen?
How much FC you need to maintain is based on what your CYA level is. Plus, if you get a little growth going you may never eradicate it unless you complete a full SLAM. Have you performed a OCLT to see if you indeed have something living in the water?
well, then if you stay above the minimum on the FC/CYA curt algae is not going to start. Vacuuming or having a cleaner (I have an M5 robot) will keep the dust/ dirt in check. I am amazed how much blows into my pool each week.
