Thread: at how many PPM can algae NOT grow?
    Every year around this time, I seem to get a whisp of greenish , yellow on the shallow end bottom. My CHL reading right now is 15 and hasnt been below 8ppm this season and i did a drop test with NO DROP Pollen?
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
    heat siphon heat pump
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: at how many PPM can algae NOT grow?
    How much FC you need to maintain is based on what your CYA level is. Plus, if you get a little growth going you may never eradicate it unless you complete a full SLAM. Have you performed a OCLT to see if you indeed have something living in the water?
    Support the site
    22,553
    Most likely pollen or dust. I think I'd aim one or two of those eight returns toward it if possible and let it keep the place clear.
    Quote Originally Posted by tim5055 View Post
    i did the OCLT, no drop overnight
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Are you brushing your pool weekly? Its one of the easiest things to forget to do, but it helps enormously.
    May 2014
    Franklin, NC
    9,193
    Quote Originally Posted by mikeginder View Post
    well, then if you stay above the minimum on the FC/CYA curt algae is not going to start. Vacuuming or having a cleaner (I have an M5 robot) will keep the dust/ dirt in check. I am amazed how much blows into my pool each week.
    Support the site
