Thread: Do I need a cove?
    Jul 2015
    Maple ridge
    1
    Do I need a cove?
    I have 12' 48" best way steel wall pool. 2 questions , do I need a cove?
    also one of my support legs won't connect to the base plate...can't line up the holes. Any idea what is causing that?
    thanks
    Jun 2012
    western NY
    1,560
    Re: Do I need a cove?
    The cove helps lock the pool wall into the bottom track and also prevents any contact between the support blocks under the uprights and the liner. As for the leg/base plate issue, a picture might help us see what you are up against.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    May 2012
    Montville NJ
    545
    You need a cove.
    without a cove, the weight of the water on the liner can cause the liner to push out under the bottom track, and then you will be in a world of trouble.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Casey's Avatar
    SW PA
    10,444
    Quote Originally Posted by phonedave View Post
    You need a cove.
    -dave
    Agreed.
