Results 1 to 18 of 18
Thread: Which Deck?? Full wrap around, partial wrap around, or end deck only??
    Nov 2014
    North Bergen, NJ
    15
    Just wanted to get some input.. We are talking with a few deck guys and pricing things out but figured I would get some outside opinions.. We are on the fence about what type of deck to do around the pool.. We always figured we would do a full wrap around but are now starting to think that it would be nice to have a "direct" view into the pool versus having to look through a railing.. It would be especially nice during a party or gathering to be able to see and communicate with people inside the pool.. The pool will be an 18 x 33 semi inground.. At this point we are figuring that it will be anywhere from 27-36 inches above ground at most.. The three options we are considering are:
    1. 3/4 wrap around with 8 or 10ft x 21ft lounge deck on one end and rest being 3ft. This would leave the front open with no railing..
    2. Full wrap around with 8 or 10ft x 24ft lounge deck on one end with the rest being 3ft.. This would have a full railing all the way around..
    3. Just an end deck being 8 or 10ft x 24ft.. No decking on any other sides..
    Below are some quick pictures I drew up to give an idea on what we are talking about.. Not to scale or anything like that.. Appreciate any input.. Also, on a side note, I apologize in advance if this is not the correct space for this type of question but thought it would be part of the "build" section.. Thanks
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Which Deck?? Full wrap around, partial wrap around, or end deck only??
    Direct view and full deck if you ask me.
    Essential Links:
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,457
    Full deck or 3/4 deck NOT the just the end deck.
    Full deck------how many people do you really think will be at your pool some days? That will give a lot of walking (or running if they are kids) room. It will make cleaning the pool nice as you will be able to walk all the way around the pool and not have to get in on those days.
    3/4 deck-----if you have a lot of people this MIGHT work but there could be come traffic congestion with this one. Again it will help with the cleaning if your pole is long enough to reach the other side. It will be harder than the full deck
    NO just end deck as the cleaning will be MUCH harder because you will have to be leaning over the sides of the pool to brush the walls.
    Kim
    Cypress, Tx.
    154
    Buy as much deck as you can afford.
    Intex 18ft dia. Ultraframe, 6500 gal. above ground Intex pool with Hayward C550 cartridge type filter and Intex Krystal Clear Ozone and saltwater system model ZS8110, Taylor K-2006 test Kit, Pool filter supplemented with Duda Diesel 1 micron filter bag
    Located in Cypress, Tx.
    Jun 2014
    Northeast Alabama
    98
    ^^^Ditto^^^
    33 Round AGP, 26K gal, vinyl liner, 1 HP single speed pump, 1 Hayward wide mouth skimmer, Pentair sand filter, Taylor K-2006 test kit, Red Leopard Orbit suction auto vac, Pool School, TFTestkits, PoolMath, Support this Site!
    May 2014
    Clarksburg, WV
    331
    I have a 24' round pool. I did the middle pic. 3' on 3 sides and 12' on the long end.
    We love it. Still under construction, but its super nice to have lots of room. and good choice going with 3' on the 3 sides. I almost went with 2' and SO SO SO glad somebody here talked me into going 3' instead.
    24'x54" 15k AG round - Outback Genesis
    1 1/2hp Hayward Matrix 2 speed. Hayward 180T Sand Filter
    TF-100 Test Kit
    Pool School & TF-100
    How to SLAM
    Mar 2014
    Northeast PA
    8
    I am currently doing the same with my 18x45 above ground pool. I would say first check with your building codes. With the pool being only that high off the ground you may end up having to place a fence around the pool if you decide to do either the 3/4 or end deck. If this would be the case you would end up loosing the view you want and I would rather imo have the deck to look at instead of a fence. However if you would only need the fence around the yard you can do whatever you want.
    I am with the others though the full deck is great and makes cleaning the pool easy. I am doing the full deck and have not regretted it as it gets used a lot. I also am currently building benches instead of railing that doubles as storage for all the kids toys. And planters for my wife's flowers to make it more inviting. Just an idea and a quick search of the Internet can give you more ideas to add to the beauty of the deck and pool.
    Mike.
    I have a 18x33 Oval Above Ground pool we had installed 2 summers ago. We did a 18x24 deck on just the end, I would have LOVED to put it up more, however, we went with trex, and it was VERY EXPENSIVE, the materials alone cost us I think a little over $4,000 and that was not including the install !!! we are just a family 3, so it suits us just fine, but when we do have a pool party I wish I had it larger, however we have lower deck with a hot tub, a high deck (back of our house is not under ground), so this was our 3rd deck being built, no way I could convince my husband to spend more $$ on decks! I don't blame him though.20130915_171855.jpg
    sorry I meant 10x20 deck
    18K gal 28ft round AGP, Hayward Power-Flo LX 1.5HP pump, Sand filter
    Nov 2014
    North Bergen, NJ
    15
    Thanks for all the input...
    MikeTinnelle: The ordinance in our area is that the yard has to be closed in by a 6ft fence and have a latching/locking gate.. As long as that is done (which we already planned on doing) then we do not need any gate around the pool itself..
    Fitness4Life: Any more pics? We had a family friend that does small projects take a look at our ideas.. I know he said one of the big things is that we are going to need A LOT of posts/footings if we do the full wrap around.. We told him we wanted to do a composite material and he was estimating he could probably get all the material, and just material, for about 7k to do the job.. That didn't include any kind of install price which around here is probably at least equal to the materials cost.. We are waiting for an "official" estimate but we are figuring it will be about 15-18k just for the deck for a professional company to come in.. Obviously we could just do a wood deck and the price would probably be cut in half, however we prefer the composite material..
    May 2012
    Montville NJ
    545
    Depends on how tall you are.
    My deck is around about a quarter of my 27' round. I have no problem cleaning the pool from the out side where there is no deck - but I am 6'4". My wife an kids say they cannot reach from the outside. I am beginning to think that is just an excuse not to clean the pool.
    While I would like a walkway all the way around my pool, I don't think I would like the way it would look. My pool is on the ground, so it is 48" high. adding a deck railing to that height all the way around would not look good.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Mar 2013
    Central Iowa
    169
    This is not my photo. I found it on the internet. I love these kind of stairs. I think they make it look very inviting to come up to whatever is on the deck. Keep your same configuration with the big deck area at one end and put these kind of stairs towards the house or other gathering area of your yard.
    http://deckdesignspictures.com/Above...s-Pictures.php
    2014 Used 33'x54" Wilbar Morada,deep end approx 28,800 gal.
    Hayward S180T1580S pump/filter combo,
    Pentair Aqualuminator light/return, Aquabot S2-50
    TF-100 kit, Initial fill with pond water
    South Central Iowa
    Jul 2012
    Tallahassee, FL
    30,457
    OH WOW! That first pic is THE way to go if at all possible! WOW WOW WOW!
    Kim
    Here are some more pics...as you can see we didn't attach our lower deck, I wish we did, however, I want to say our deck cost between 7,000-8,000 (I can't remember) and that is with composite material, and little did we know that we had to build a retaining wall when we put the pool in which we added to our costs, otherwise I think we would have connected the hot tub deck to the pool deck. We are in MA so the guy put in 6 sonar tubes 5 feet down protect against frost heave, we left a little space (as recommended by pool company in case repairs, etc. need to be made). These photos will give you a good Idea of what your pool will look like with just end.
    sorry for some reason every time I try to load more photos no matter how much I compress them I keep getting an error message.
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    333
    Won't you need to have an enclosed stair with self closing gate for entry to the deck if you go full. I had to get one down here. I have MFG fencing all around the pool with a 10x5 side deck. (Wish I did the end deck but would have cut into the yard too much.) How high can you be above grade and not require railings?
    I'm half 2' below grade and at grade on the long sides. We got the fence to prevent anyone (little ones) from pulling something up to the side and climbing in.
    When I vacuum and brush I just walk on the top rail around the pool.
    I like the full deck. My brother has a round ABG with a huge L shape deck and I love it. Room for table w/ umbrella and loungers.
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
    R.J.'s Avatar
    Jul 2012
    Minneapolis
    82
    If you go with the end deck, you might end up wishing later that you had a larger deck. I doubt that will happen if you go full deck. Every time you use the wrap around portion for cleaning, jumping in or retrieving items from the pool, you'll be glad you have it.
    18 x 48 Intex Ultra Frame
    2500 gph cartridge filter
    Intex SWG
    Mar 2014
    south central PA
    112
    If you can go all the way around, I'd do it (but it's expensive with all the footings!). We are about 3/4 the way around (maybe? maybe a bit less?) and while we love it, I have 2 big pet peeves...1. When stuff floats to the far side where the deck isn't, I can't get it (I'm short, our pole sucks) and 2. The kids are forever shooting toys over the edge. Drives me nuts (as I'm usually the one retrieving them).
    Eventually we will probably go all the way around.
    28 ft round ABG with ~6ft deep end, approx. 20,000 gal, 2 spd 2 HP pump, sand filter
    May 2014
    Clarksburg, WV
    331
    Footings and post holes were the worst part of my deck. 44 post holes. My shoulders hurt for days....lol
    TF-100 Test Kit
    How to SLAM
