Thread: skimmer leaking. need ideas? HELP
    Jul 2015
    stow ohio
    1
    Question skimmer leaking. need ideas? HELP
    ok brief history. I got this pool (used) brought to me by my boys. set it up, filled it, swam in it, now kinda like it. BUT, my skimmer has been leaking just about anywhere a skimmer can leak since we set it up. I replaced he skimmer today once I finally found out what I have. its a light house brand only wide mouth skimmer. . when I removed the skimmer I found the liner around the hole is in bad shape. tried to just install and hope for the best but now it leakes more than ever down the outside wall. What I think I need to do is to get a large heavy patch and put it across the whole skimmer hole , then install the front of the skimmer and cut out the skimmer like when you replace the liner. has anyone heard of this. I am open to a better idea. thought about adding a bigger rubber gasket. etc. any and all help would be great. leak is killing my water bill
    21ft basic light house brand pool
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: skimmer leaking. need ideas? HELP
    I would attempt the large patch. You wouldn't necessarily have to cover the whole skimmer hole with a patch, just do wide strips all the way around the existing skimmer hole. That may or may not work but I think it's certainly worth a try.
    Amazon.com : Hydro Tools 8815 4-Ounce Vinyl Pool Linear Repair Kit : Swimming Pool Maintenance Kits : Patio, Lawn Garden
    or
    Amazon.com : Boxer - 4 oz Vinyl Swimming Pool Liner Repair Kit : Swimming Pool Maintenance Kits : Patio, Lawn Garden
    Those could work well. I've never done any patching myself so perhaps someone else can chime in as to what type of patch works best.
    Isolated Spa - 345 Gallons
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    What exactly does bad shape loos like?
    My new skimmer leaked due the fact I had the outer surface developing rust and pitting. The lining had to be trimmed also but all in all was OK.
    If the lining is still continuous, you could possibly clean it and try silicone caulk on both sides, lining and outside of the pool. Or you can patch it.
    Seasonal World rectangular pool, 27K gallons (data sheet), 25.3K calculated
    Jandy Stealth JHPU 2.0 PUMP, 2HP
    Jandy CL340 cartridge filter
    Pentair C320 inline chlorinator
    AquaComfort heatpump heater
    April's Avatar
    Apr 2014
    KY
    138
    My skimmer was leaking on the outside also. All I had to do was tighten the screws on the skimmer and problem was fixed. Have you checked the screws?
    18ft Round AG, Vinyl, 100LB Pentair Sand Filter, 1HP, June 2012, TF-100 w/SpeedStir
