Thread: Cell resistance curiosity
    Jun 2015
    Ocean Springs MS
    12
    Has anyone measured the resistance of their cell with it wet and the pump running? Mine shows 0 ohms (dead short) when it's in the housing full of water and I'm just curious if this is correct. It shows "open" when out of the water and dried off.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Cell resistance curiosity
    It shouldn't be 0 Ohms but it will be low. The Pentair IC20/40/60 power center is nominally outputting 35V at around 5.7 Amps (it's limited at 6 Amps) so that implies 35/5.7 = 6.1 Ohms. Either you have a short in the cell (if you find it's not working) or your meter isn't right or you aren't measuring correctly.
    JoyfulNoise's Avatar
    May 2015
    13,187
    You typically can't use a handheld meter to measure an electrochemical cell. Handheld meters do not typically generate voltages high enough to properly test cell resistance. Also Electrochemical cell resistance is not linear like a real device resistor (metal film resistor, etc).
    Matt
