Results 1 to 14 of 14
Thread: Where is all my Cl going?
    Jul 2015
    San Jose
    10
    Hello all
    New house and a new pool
    We inherited a high CH, TA and CYA. I've read around on the site enough (and posted a question) to know that I need to have higher FC because my CYA is high.
    Yesterday I put in 4 gallons of 10% liquid Cl,
    Today I tested and got the following
    7.8 pH
    2 FC
    140 TA
    100 CYA (I diluted the sample 2:1 with tap water and measured 50 ppm)
    I also tested CH but the sample never really turned blue, around the 40 drop point it turned clear.
    Now all that being said, I recognize I don't have the best test kit for Cl, all I have is DPD, not FAS. That is on order, so I hope to have a clearer picture soon. but I still expected higher FC today.
    Thanks in advance for your help.
    Aprox. 15000 gal in-ground plaster pool. 4 speed pump with a cartridge filter.
    Spa and gas heater attached.
    Ca resident = water restrictions
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    Re: Where is all my Cl going?
    How does your water look? Are you seeing algae, cloudy water, weirdness?
    Your CL is being consumed by something...and since your CYA is so high we've got to assume its algae. Not all algae is visible in the water.
    You also need to do a 3:1 dilution for a CYA test. You really might be much higher than 100, y'know? I know you're in CA so not sure if any water replacement is possible? But you're going to need a LOT of liquid chlorine to deal with a CYA of 100+
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum!
    More than ever, over stabilized pools are a FRUSTRATING problem with drought stricken CA. Unfortunately, reduction by water replacements is the only dependable answer unless RO treatment is available to you. If so, it's expensive, but perhaps worth a look, as you are quite likely to have higher than 100 Cya. As asked above, please tell us how the water looks, and what problems your having or have had lately.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP! Congrats on the new pool!
    4 gallons of 10% adds 27ppm FC to 15k gallons. The only thing that can consume that much FC is algae or organic matter. Seems like you will need to Pool School - SLAM - Shock Level And Maintain the pool.
    Jul 2015
    San Jose
    10
    Thanks all!
    I do live in california so draining is not an option. We are getting it resurfaced this winter, so that will be a good reset, but until then I just have to fight it. Couple of things to add;
    1) To test the CYA, I first did it per the instructions but got greater than 100. Next I diluted the pool water with tap water 2:1 and then ran the test and got just under 50. Why is that dilution ratio not accurate?
    2) The water looks OK, it is not what I would call sparkling maybe slightly cloudy.
    3) Is it possible that my test is just wrong and I should wait until I get the better test kit in the mail? Which I will have to do anyway since I will need it to do the Slam.
    4) Is it possible that dog hair could cause this? Could that be in the filter (although I recently cleaned it) and absorbing Cl? I have a lab that is always jumping in.
    5) I added 4 gallons and got an additional 1 ppm Cl. According to the chart I have to get to 39 to Slam? That seems crazy. And I will have to maintain 12 ppm until I can do a water replacement? That seems crazy too. I know the bio active has caused more issues than it solved, but I don't seem to have a lot of options.
    Jul 2015
    San Jose
    10
    I think I may have answered my question with the dog hair...... Maybe I will go to a weekly pump filter cleaning. He is an old boy, so keeping him out of it would be tough.
    What about running a simple test, where I clean the filter then add the Cl- to see if it stays there? If it does, then I know what the issue is.
    DFW, TX
    24,497
    Yes, those chlorine numbers are correct. The cloudy water is usually an early sign of an algae bloom. Yes, the dog is likely adding organic material that is consuming chlorine. Making it more important to keep FC around 12.
    If the DPD test says 2 then it probably is. But, I'm not sure, I don't have one. I use OTO and FAS/DPD. I am comfortable with your cya reading of 100.
    Keep in mind that the PH test is not valid when FC is above 10, so test and adjust when FC drops to 9 or 10.
    Jul 2015
    San Jose
    10
    Thanks. I'll clean the filter and keep adding Cl. I don't want to do a slam until I get my test kit (plus I'm out of town this weekend). Should I even worry about the high TA at this point?
    DFW, TX
    24,497
    No, TA isn't that high. Just maintain your PH between 7.2 and 7.8. When it gets to 7.8 add muriatic acid to lower it to 7.2. Tjis will slowly lower your TA.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    If draining isn't an option, how will you resurface the pool? If you can do it later, why not now as well is what I'm getting at.
    Essential Links:
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    i believe a dog swimming in pool was equal to 20 people in terms of chlorine loss per hour of swimming
    i cant find the post now though
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by aussieta View Post
    If you can find that post, I would like to see it. Not sure about that, certainly not as a given.
    The bigger point here, dog or not, is the Cya. When you get into trouble with high Cya, it can be a monster to overcome.
    Essential Links:
    Sep 2013
    Connecticut
    728
    Just double checking on your dilution procedure - when you say 2:1, does that mean one part plain water to one part pool water? Or two parts plain water to one part pool water? If the latter, the result needs to be multiplied by 3.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Jul 2015
    San Jose
    10
    In San Jose CA right now I am told you can drain and refil your pool only if you have a leak. We do have a leak in that our skimmer is cracked near the top. As long as I keep the water level a little low (but not too low to cause issues) I don't loose any water. I am hoping that loop hole will let me drain the pool to fix the plumbing. (Also pulling up all the cement and redoing that back yard completely - which would lead to more leaks) At that time I will resurface. We will also be doing this in the winter, hopefully by that time we will have had significant rainfall.
    As for the dilution procedure,
    I took 5 ml of pool water and mixed with 5 ml of tap water. I then ran the CYA test. I should have wrote 1:1, sorry about that.
