Thread: Which valves do i leave open during filtering?
    Jul 2015
    Boston/MA
    30
    I have 3 valves/pipes?
    They're labeled as Main Drain/ Shallow Skimmer/ Deep Skimmer.
    Which ones do i leave open/close when i am filtering/backwashing. Sorry if this is a dumb question, i'm still new to managing pools and slowly learning my way up.
    Thanks for any advice!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Re: Which valves do i leave open during filtering?
    All of them. You don't need much on the main drain. I would just open it a little bit until you just start to see a difference in the skimmer turbulence. Then you'll want to close off the closer skimmer a little bit until the flow looks equal inside the two of them.
    Jul 2015
    Boston/MA
    30
    Thanks for the response. How would i be able to judge the flow between the two of them?
    Richard320's Avatar
    Jan 2010
    19,000
    Quote Originally Posted by IABO View Post
    Look inside the skimmer well and try to match the turbulence. Aiming returns and balancing flows is more art than science. Just experiment.
