Thread: What time to start OCLT?
    Jul 2013
    North Canton, OH
    192
    Sunset here is at 8:52 today in my location. Can I start the OCLT at 8:53 as quick as the sun is below the horizon? Or does indirect sunlight affect it meaning I should start later? If later, how much later?
    30,000 gal IG 20x40 8ft deep end vinyl liner in NE Ohio DOB Sept 2012
    Hayward 4820 DE filter, Hayward SP2610x15 1.5HP single speed pump
    Hayward H400FDN natural gas heater, Frog min'l/Cl2 system (not in use)
    autocover, Dolphin DX4 cleaner, well water, TF100 test kit
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Re: What time to start OCLT?
    I would say just to be on the safe side, right about the time it gets dark.
    Divin Dave,
    Jul 2013
    North Canton, OH
    192
    The are different definitions of "dark." Civil dusk is about 30 minutes after sunset in my area at this time of year, and the horizon and terrestrial objects are easily distinguished still. Nautical dusk is about 40 minutes after that, the horizon is barely visible and the general outlines of ground objects are still distinguishable. Astronomical dusk is still 50 minutes later, the horizon and ground objects are indistinguishable, and astronomical objects are fully visible. So if I want to wait until it is "fully dark," I have to wait until about 11:00 to start the OCLT. That is past my bed time LOL.
    How long after sunset do people usually wait?
    Casey's Avatar
    SW PA
    10,418
    When the Sun has beaten you to bed.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    I would test between 9:30 and 10:00
    Husky25's Avatar
    Jun 2015
    "East of the River" CT
    439
    Bedtime, just to be sure. In my case that means some time between 9:30 and 11:00. Sun-up is also subjective. This time of year, I'd say about 4:45.
    Chris
    Outdoor in-ground 18' x 36' rectangle w/ vinyl liner. 2 returns, 2 drains, single pool side skimmer, ladder, diving board, LED multi-color light, Pentair Cristal-Flo II Sand Filter, Sta-Rite Super Max 3/4 HP Pump, AquaCal heater, SpeedStir, TF-100. Baquacil Conversion of former pool - June 2015, SLAM How-to, Chlorine/CYA Chart
